TSR intake component - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: TSR intake component (/showthread.php?tid=6026) |
TSR intake component - Oboro_imp - 06-30-2014 So I just received this today and it looks like it should just be a straight bolt on piece but there is instructions in Japanese with various pictured parts circled. Is there any special considerations installing this part? Thanks Randall Re: TSR intake component - Dengie Boy_imp - 06-30-2014 Remove the socket screw from the right hand side cover, lift off, undo the 3 phillips #2 cross head screws from the intake trumpet (you will need to pull the cable loom away near the frame tube), wriggle off the trumpet and replace this with the TSR unit. 5 minute job. RE: TSR intake component - Oboro_imp - 06-30-2014 OK cool. I figured but it's better safe than sorry! |
