Exaust pee - Printable Version
+--- Thread: Exaust pee (/showthread.php?tid=5806)
Exaust pee - BigRock_imp - 06-19-2015
After servicing my 2014 DLX I noticed liquid under the right side exhaust. Checked it, definitely H20. No H20 on the left side. After getting underneath I could see a drain hole for the moisture, condensation drain I figured. Makes sense since the exhaust tilts up and won't send the H20 out the end. Checked the other side. The black coating is covering the hole.
[url=http://s1208.photobucket.com/user/markwil1/media/103800%20TU.jpg.html][Image: cd2d9d90140b126fc208d02a069e87a3.jpg]
I opened the hole and H20 came out.
[url=http://s1208.photobucket.com/user/markwil1/media/103832%20TU.jpg.html][Image: e92c72c7dd452a801be0d1420882b7c6.jpg]
I suggest you check to see if you bike is Peeing.
[url=http://s1208.photobucket.com/user/markwil1/media/104235%20TU.jpg.html][Image: 4e558269af16182e89dad21e9f12dad9.jpg]
RE: Exaust pee - the Ferret - 06-19-2015
Yep, mentioned this before. Make sure both of those blow holes are clear and that upon start up both " pee" as you put it. Without those holes condensation has no where to go but puddle in the lowest part of the pipes. Whenever I wipe off the pipes I stick a nail up in mine and wiggle it around to make sure they are clear.
RE: Exaust pee - Motogeezer1949_imp - 06-19-2015
Trapped condensation is not our friend. Especially if we don't ride much Wink
RE: Exaust pee - immgunn_imp - 06-19-2015
I think catalytic converters create one (1) gallon of water for every gallon of fuel burned.
