Pin description - Printable Version
+--- Thread: Pin description (/showthread.php?tid=5686)
Pin description - Volchkoff_imp - 12-15-2015
Dear friends,
I am going to install the alarm system. To do it I removed plastic box under the seat and found plugs, connected to turn signals etc.
I listed manual, but didn't find pin description of those sockets. Could you help me with that kind of information? Or just a photo of electric scheme.
RE: Pin description - Lord Popgun - 12-15-2015
Are you saying you looked in the manual? Look at the wiring diagram. It shows all the wires and wire colors for all the connectors.
RE: Pin description - Volchkoff_imp - 12-15-2015
I have only general manual. Not service manual.
RE: Pin description - curlyjoe - 12-16-2015
Here's a link where you can download a hi resolution photo of the 2013 CB wiring diagram
https://drive.google.com/file/d/0B9GzDu4Xke2FclhzZTdiZ09aUXA5N3E0STJCQWlNdXBnbmEw/view?usp=sharing
RE: Pin description - Lord Popgun - 12-16-2015
On the google link it actually isn't tooo bad. If you could lay it flat and shoot it with some white(er) light, it would be very useable.
I can scan the diagram, but my scanner will not do the whole page. Have to do it in 2. I already have the scans for the '13. Cannot post them here as it is copyrighted and thus not allowed on the site.
Then I shouldn't have posted the photograph due to copyright restrictions?
Curly,
If its a problem, Ferret will take care of it. Don't worry. Smile
Ok, I removed the useless low res photo and have updated the google link to a photo that's a bit better.
RE: Pin description - Volchkoff_imp - 12-16-2015
Thanks for the help
Volchkoff,
This link, just posted, has a picture of the headlight shell. If you look at the bottom you can see a red, plugged connector. That is the accessory connector and the one by the battery is the same. http://cb1100forum.com/forum/showthread.php?tid=7548&pid=115378#pid115378
You have to look at his new shell as you can't see it in the original he posted.
