Speedbleeders - Printable Version
+--- Thread: Speedbleeders (/showthread.php?tid=5082)
Speedbleeders - quail_imp - 05-16-2016
I love these things.
I just received the PDF file from Goodridge for all their brake parts they list speedbleeders SB125 AND SB125L. Has anyone ever bought these for the CB1100? Is one nipple left hand thread? It shows the clutch takes one of these numbers also.
RE: Speedbleeders - TINK_imp - 05-16-2016
Have them on my ABS ST1300, they are a Godsent!
RE: Speedbleeders - quail_imp - 05-16-2016
(05-16-2016, 10:25 AM)TINK_imp Wrote: Have them on my ABS ST1300, they are a Godsent!
TINK
on other forums I bring up speedbleeders and everyone tries to tell me how to bleed my brakes with out them. They are so cool I change my fluid every year in about 30 minutes. Yes they are Godsent! By my chart the same ones should fit the CB1100 also.
RE: Speedbleeders - 12cb96vfr_imp - 05-16-2016
the L stands for Long. i have 'em, they are awesome
RE: Speedbleeders - redbirds_imp - 05-16-2016
(05-16-2016, 11:14 AM)12cb96vfr_imp Wrote: the L stands for Long. i have 'em, they are awesome
Is the speedbleeder for the clutch same as for brakes? I am going to order these, tired of bleeding brakes the old way.
RE: Speedbleeders - Cormanus - 05-16-2016
TINK
As I've often said, I'm a mechanical klutz, and I've never bled a brake in my like. I looked at the SpeedBleeder website and I can't understand why, if these things work, you'd argue for people to bleed brakes and clutch the old-fashioned way.
do you know if the part number is correct?
TINK
I did a search on speedbleeders and found an old thread on the subject, over 1/4 of the post were members telling the speedbleeders how to bleed the old way(s).
I bleed my work trucks brakes the same way in about 45 minutes. 4 trucks later, 16 complete brake fluid changes, and I have been using the same bleeders for years.
RE: Speedbleeders - lola_imp - 05-16-2016
Would be great to find out which one works with our brake and clutch system .... let's know thanks!
TINK
TINK
Ya, right, YOU bleed without them, thank you, I'll keep using speedbleaders.
I also have them on my 2000 VFR800 which has the famous (infamous) Honda combined brake system.
RE: Speedbleeders - 12cb96vfr_imp - 05-17-2016
yes they are the same - sorry fellas i just saw this
the size for both is 8x1.25 - look at the attached pic, but bottom 3 in the center are
8125, 8125l and 8125ll
you'll see that 8125 and 8125l are only different on the "top half" the thread length and pitch are identical. you could put whatever one you want on your bike...i went with 8125l for both brake and clutch so the bleeder hose has something to grab on to.
http://www.speedbleeder.com/size.htm
sorry pic attached
