Can I add ABS to Non ABS 2013 - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Can I add ABS to Non ABS 2013 (/showthread.php?tid=4849) Pages:
1
2
Can I add ABS to Non ABS 2013 - HWdesign_imp - 03-27-2020 hi I have a non ABS 2013 and I am exploring what would be involved to add ABS to it. Any advise would be welcome. It's probably not worth it but I thought I would ask. thanks HW RE: Can I add ABS to Non ABS 2013 - pekingduck - 03-27-2020 The change to ABS would entail about $2500 worth of different parts. The modulator alone is over $1000, plus you'll need a different caliper, wire harness, and many misc smaller items. Not including the meter, another $600 if you want the indicator on the dash. Plus labor. About the price of a good used ABS model. RE: Can I add ABS to Non ABS 2013 - HWdesign_imp - 03-27-2020 (03-27-2020, 01:05 PM)pekingduck_imp Wrote: The change to ABS would entail about $2500 worth of different parts. The modulator alone is over $1000, plus you'll need a different caliper, wire harness, and many misc smaller items. Not including the meter, another $600 if you want the indicator on the dash. Plus labor. About the price of a good used ABS model. thanks I figured as much. Do you know if there is a caliper that would replace the stock that would be better. RE: Can I add ABS to Non ABS 2013 - pekingduck - 03-27-2020 (03-27-2020, 01:16 PM)HWdesign_imp Wrote:(03-27-2020, 01:05 PM)pekingduck_imp Wrote: The change to ABS would entail about $2500 worth of different parts. The modulator alone is over $1000, plus you'll need a different caliper, wire harness, and many misc smaller items. Not including the meter, another $600 if you want the indicator on the dash. Plus labor. About the price of a good used ABS model. thanks I figured as much. Do you know if there is a caliper that would replace the stock that would be better. Curious, what about the brakes do you not like? RE: Can I add ABS to Non ABS 2013 - HWdesign_imp - 03-27-2020 The pads are basically new and the grip, especially on the rear is soft. I'm used to them but I was curious if I had any options. RE: Can I add ABS to Non ABS 2013 - Guth_imp - 03-27-2020 (03-27-2020, 01:39 PM)HWdesign_imp Wrote: The pads are basically new and the grip, especially on the rear is soft. I'm used to them but I was curious if I had any options. Can you by chance better define "soft"? RE: Can I add ABS to Non ABS 2013 - Cormanus - 03-27-2020 I think it’s fair to say the general consensus on the forum is that the front brakes on the CB1100 are excellent and the rear is adequate. RE: Can I add ABS to Non ABS 2013 - Guth_imp - 03-27-2020 Not quite helping though Cormanus. I know that some were soft in that they couldn't even lock up their rear brakes if they tried while others have no problem doing so at all if experimenting (myself included). So I was wondering where HWdesign fits into this spectrum from the perspective of both his front and rear brakes. Can I add ABS to Non ABS 2013 - Pauley - 03-27-2020 You might try bleeding the rear brake. RE: Can I add ABS to Non ABS 2013 - Lord Popgun - 03-27-2020 (03-27-2020, 02:31 PM)Pauley_imp Wrote: You might try bleeding the rear brake. Do this first. At least 4 of us had air in the rear brake from the factory. But its still not as good a brake as the fronts. |
