Seafoam: Yes? No? When? Why? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Seafoam: Yes? No? When? Why? (/showthread.php?tid=2538) |
Seafoam: Yes? No? When? Why? - glenridgerich_imp - 02-07-2016 Anybody have an opinion on Seafoam? Should I use it? And if so, when and why? Thanks! RE: Seafoam: Yes? No? When? Why? - kmoney_imp - 02-07-2016 I've used it in cars and found it to be very effective. That is using the sucking it in through a vaccum line method. I've never really bothered in bikes, because my bikes seem to have way fewer combustion chamber deposits -- being ridden hard and hitting redline vs. essentially loafing/lugging around all the time. If you want to get rid of some carbon deposits though, I'd say this is the best product I've used. RE: Seafoam: Yes? No? When? Why? - the Ferret - 02-07-2016 I use it in all my bikes and lawn equipment and have never had a problem with the carbs. 1 oz per gallon in summer in the bikes every few months just to keep carbs/injectors clean. 1 1/2 oz per gallon of gas in the bikes if I think they are going to be sitting any length of time (a few weeks) Just today on my way home from a ride I filled up the CB, it took 2 1/2 gal gas. When I got home I put 2 1/2 oz of seafoam in the tank. Just in case the end of Feb is bad and I can't ride it. 1 oz per gallon in all the lawn equipment at the end of season in fall. 1 oz per gallon in the ATV and snowblower in the spring. Everything gets run until I feel seafoam has made it thru the carbs. I buy Seafoam by the gallon. I am a believer. RE: Seafoam: Yes? No? When? Why? - Retsel_imp - 02-07-2016 Agree with ferret. I bought a used 15 year old Valkyrie with less than 3 K miles. So it had sat for some time. We are talking 6 carburetors. It had some major low idle, low speed issues. To the point I was on the verge of pulling and re building the carbs. Ran sea foam, at one oz per gallon, for about three tanks and could not believe the difference. If solved all the problems. I now run sea foam in all my motors. Autos, compressors, power washers, lawn mowers, weed eaters, and motorcycles! It works. RE: Seafoam: Yes? No? When? Why? - redbirds_imp - 02-07-2016 I use it regularly in my small motors. Great stuff. RE: Seafoam: Yes? No? When? Why? - flynrider - 02-07-2016 I treat my gas with Seafoam a couple of times a year just to keep the fuel system clean. I've been doing this with the CB750 for as long as I can remember and it's carbs have never been off. I do the same with the CB11 and my truck to keep the injector screens clean. Like Retsel, I've used it in the past to clean up the carbs on bikes that had been sitting with old gas in them. If you got to them before the small passages or jets were completely clogged with varnish, you could often avoid pulling them. Basically, it's an excellent solvent for dissolving unwanted deposits in the fuel system. RE: Seafoam: Yes? No? When? Why? - Catbird_imp - 02-07-2016 I just used it in my small, 10 year old snow blower which has a 2 cycle engine to keep it running well. It seems to work as advertised. RE: Seafoam: Yes? No? When? Why? - Rocky_imp - 02-07-2016 Everything I've ever heard about Seafoam has been very positive. RE: Seafoam: Yes? No? When? Why? - coach50_imp - 02-08-2016 I stay away from the aftermarket fuel additives, except over the winter, I add Marine version of Sta-Bil 360. I try and only use fuel from those brands rated as "Top Tier", which allegedly means additional additive packages. There are some videos on U-Tube that seem to indicate Sea-Foam, and other additives, dont do all that much...YOMV. Cheers
RE: Seafoam: Yes? No? When? Why? - LongRanger_imp - 02-08-2016 I've had good success treating gas with Stabil, but I'll try Seafoam when it's time to buy more based on the testimonials I've read. That being said, I've never experienced any issues with Stabil. |
