What is this part? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: What is this part? (/showthread.php?tid=15046) |
What is this part? - Easynow - 09-12-2026 2014 cb1100ex (sae) ![]() ![]() Any ideas, folks?! From near the airbox, throttle body area. Although may have fallen from somewhere else. Cheers clever clogs! RE: What is this part? - pdedse - 09-12-2026 (Yesterday, 03:07 PM)Easynow Wrote: 2014 cb1100ex (sae) Small detail but it wouldn't be a 2014 EX, the EX is for the 2017 models. If 2014, it would either be a Standard or a Deluxe model. But, uploading the photo to AI and asking what it is, I got the response: "Based on the shape and the clue that it comes from a Honda CB1100, that part is a Rear Chain Adjuster Plate (sometimes listed as an Adjuster, Chain or Chain Tensioner Link in parts catalogs). How It Works:
But I'm not believing AI for this. Others? RE: What is this part? - Easynow - 09-12-2026 Apologies, I colloquially use EX since that's what I gather the equivalent U.S. model that came a little later was known as. This is the European SAE model, (deluxe?).. six gears square tank spokes abs etc. Anyway, I do not believe AI on that one either! Only thing I see that could be similar is this pair of blind mounting holes for the rear brake reservoir?: ![]() Edit: turns out no, these are seperate captive nuts.
RE: What is this part? - pdedse - 09-12-2026 (Yesterday, 03:34 PM)Easynow Wrote: Apologies, I colloquially use EX since that's what I gather the equivalent U.S. model that came a little later was known as. This is the European SAE model, (deluxe?).. six gears square tank spokes abs etc. No, I'm the one that owes you an apology...Moderator Cormanus pointed out to me in a private messsage that: "Only in the US was there a DLX. The rest of the world knew the more expensive 2014 model as the EX." So I learned something new! Thanks Cormanus. RE: What is this part? - Easynow - 09-12-2026 That's alright - hopefully this part is identifiable in any case, and I can find out if I should be worried or not. RE: What is this part? - Lunchbag - 09-12-2026 I think it's this: RE: What is this part? - Easynow - 09-13-2026 Fantastic! Thank you sir! Now I have to remove the tank. Balls. |
