Is there a name for when a bike doesn't want to go into first? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Motorcycling - General (https://cb1100forum.net/forum/forumdisplay.php?fid=19) +--- Thread: Is there a name for when a bike doesn't want to go into first? (/showthread.php?tid=13171) |
Is there a name for when a bike doesn't want to go into first? - postoak_imp - 05-23-2020 I've heard of false neutrals, which I assume means you put the bike into neutral and then it slips back into first, but is there a name for the opposite -- where you can't get the bike into first from neutral without rocking the bike or letting out on the clutch and then putting it back in? RE: Is there a name for when a bike doesn't want to go into first? - Lord Popgun - 05-23-2020 Its called normal operation. Due to the way the transmission works. RE: Is there a name for when a bike doesn't want to go into first? - the Ferret - 05-23-2020 Poastoak is this obn a CB or on your FJR?. Are you down shifting while you are moving..... or trying to downshift multiple times once you've stopped? Are you seeing a dash --- in the instruments? (if it's on the CB?) There are really no false neutrals btw, only shifting errors. RE: Is there a name for when a bike doesn't want to go into first? - Bheezy27403_imp - 05-23-2020 I always thought a false neutral was when you are rowing through gears (up typically) and went in to neutral between gears on a shift. Happens to me occasionally on my Triumph. The Ferret is correct, mine usually occur due to a lazy foot. RE: Is there a name for when a bike doesn't want to go into first? - postoak_imp - 05-24-2020 I never had this problem on any of my three Hondas. It occurs with some frequency on my Yamaha, and I'm shifting exactly the same. If Honda made a sport tourer in the 650 pound range I'd be sorely tempted. RE: Is there a name for when a bike doesn't want to go into first? - the Ferret - 05-24-2020 There is an adjustment on the shift linkage. 2 nuts and a rod. One of the nuts is left handed. Loosen the two nuts and twist the rod until the lever moves up 1/4" and then tighten the nuts. Are you wearing the same boots all the time? RE: Is there a name for when a bike doesn't want to go into first? - postoak_imp - 05-24-2020 Thanks, I never thought of an adjustment. I'll look into it. All different kinds of footwear -- no consistency there. RE: Is there a name for when a bike doesn't want to go into first? - Gone in 60 - 05-26-2020 Occasionally I've had trouble going all the way down to 1 if I come to a stop without downshifting, then quickly try to click down to 1 after a stop. When it happens, I just release the clutch, squeeze again and it drops in. I try to downshift while still moving to avoid the problem. |
