DIY Motorcycle/ATV Lift - Printable Version
+--- Thread: DIY Motorcycle/ATV Lift (/showthread.php?tid=12906)
Pages: 1 2 3 4
DIY Motorcycle/ATV Lift - MagnaRider - 01-13-2025
Hi all,
Just sharing a project I am started this weekend. Finished the design over Christmas/New year and got material coming to build it.
Its a motorcycle/atv lift table that uses a standard floor jack as the lifting component. Its a 8' x 3' platform that gets 2' of lift from the floor. It'll have an 8' x 1' side section that can be attached for when I want to lift an ATV up. I'll keep posting pictures of the project as I build it. Total cost I have in this is just cheaper than a harbor frieght motorcycle lift of $550. If this goes well, I'll be able to design it a little cheaper for the next one if I find someone who would purchase one! As well as buying more bulk material etc.
I'm looking for ideas on quality-of-life improvements I can make to this, like some way to easily drain oil into a container or eyebolts to tie down the front or rear tire etc. Any ideas suggestions are great!
Made good progress on the lift this weekend. Both top and bottom frame put together and tacked up, and all my material cut on my wonderful bandsaw.
Bandsaw is early 1940's Johnson. Picked it up in Minneapolis 2 years ago and repainted/restored it. One of the best pieces of equipment I have in my little metalshop.
It wasn't as bad as I thought it would've been to drill accurate holes in my pivot arms and my bearing mounts with a cheap harbor freight drill press, just had to spend extra time measuring and making sure everything was square. Patience.
Last night I was able to get the assembly together and I surprised myself with how easily it jacked up and then came back down on its own weight! Now I need to finish welding the frames, add a few supports and put the top sheet on and it should be good to go for first real test with a motorcycle on it.
DIY Motorcycle/ATV Lift - mvk24_imp - 01-13-2025
Looks like a fun project, out of curiosity how much is it basically costing you in material compared to getting say the harbor freight lift?
RE: DIY Motorcycle/ATV Lift - MagnaRider - 01-13-2025
Right now I am at the same cost, about 550 for materials (1.5 x .125 SQ Tubing, 8x4x.125 sheet with cut charge, 1.5x.375 flatstock, bearings, bearing housings, and shoulder bolts for pivots). I definitely can use thinner gauge material but for my first one I wanted to go a little heavier duty for ease of making it.
Very cool Magna, I like the restoration if the old saw too. Looks like you've got a good helper there with the yellow lab. Good lookin dog!
Thank you! Dogs name is Ollie, my first personal dog and definetly my best friend.
RE: DIY Motorcycle/ATV Lift - MagnaRider - 01-14-2025
Got the frame welded up last night after work. Almost not even worth it by the time I get the woodstove going and the shop workable when its below 0 deg F out. Was happy I didn't warp anything and verified the lift still goes up and down super smoothly!
Finally, gonna warm up here in Wisconsin this week too! Getting sick of the cold and ready to ride soon!
DIY Motorcycle/ATV Lift - mvk24_imp - 01-15-2025
Haha yeah its only been in the 20s F° here and I decided to get one of those radiator style space heaters for the garage so I could try to get some stuff done but I think I need to get a fan to blow on it or something because the radiant heat seems to take hours to warm up the garage slightly.
Might switch to one of those ceramic heaters that have the fan built into it if they make them in a decent size.
Glad to hear the lift is coming along
RE: DIY Motorcycle/ATV Lift - the Ferret - 01-15-2025
My brother has one of those torpedo heaters that seems to do a good job in his 3 car garage.
RE: DIY Motorcycle/ATV Lift - Frulk_imp - 01-15-2025
Following this thread with interest. Hard to believe the HF bike lifts are $550. Bought two for $220 each about 6-7 years ago.
RE: DIY Motorcycle/ATV Lift - MagnaRider - 01-15-2025
(01-15-2025, 02:10 AM)Frulk_imp Wrote: Following this thread with interest. Hard to believe the HF bike lifts are $550. Bought two for $220 each about 6-7 years ago.
Me too, sadly I didn't motorcycle 6-7 years ago otherwise i would've gone that route. I like a fun project tho to test my abilities so I get that. Keeps me from just sitting around.
