The OBSERVED Valve Clearance thread - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: The OBSERVED Valve Clearance thread (/showthread.php?tid=4317) |
RE: The OBSERVED Valve Clearance thread - PowerDubs_imp - 07-13-2018 Sorry if this has been posted before here or in another thread. This shim kit will work for our bikes and many many others- https://www.amazon.com/Hot-Cams-HCSHIM01-Shim-Kit/dp/B000UKM6LG/ref=sr_1_1?ie=UTF8&qid=1531437255&sr=8-1&keywords=HCSHIM01 RE: The OBSERVED Valve Clearance thread - bflint - 08-04-2018 2014 CB1100DX, Mileage: 30K miles #1 - exhaust .28, .28 intake .18,.18 #2 - exhaust .28T, .28 intake .18,.18 #3 - exhaust .28, .28 intake .18,.18 #4 - exhaust .28L, .28 intake .18,.18 * T= tight .28 * L = loose .28 No adjustment needed. RE: The OBSERVED Valve Clearance thread - max - 08-04-2018 Thanks for posting the values, they seem very similar, how did you measure these? RE: The OBSERVED Valve Clearance thread - bflint - 08-05-2018 (08-04-2018, 06:10 AM)max_imp Wrote: Thanks for posting the values, they seem very similar, how did you measure these?Paid mech $525 for labor. RE: The OBSERVED Valve Clearance thread - Frulk_imp - 03-30-2019 2013 CB 1100 with 19,000+ miles on it at it's FIRST Valve check. Bike is never pushed to red line but has seen triple digits on numerous occasions. Cost: Shop checked/adjusted valves, replaced rear brake pads with ones I supplied, flushed brake/clutch lines and replaced spark plugs. $510.18 ($34.71 which was tax) Specs: Exhaust .25-.31 Intake .12-.18 #1 - exhaust .30,.30 intake .18,.18 #2 .28,.30 .18,.18 #3 .30,.30 .18,.15 #4 .30,.30 .18,.18 RE: The OBSERVED Valve Clearance thread - GoldOxide_imp - 03-30-2019 (03-30-2019, 03:13 AM)Frulk_imp Wrote: 2013 CB 1100 with 19,000+ miles on it at it's FIRST Valve check. Bike is never pushed to red line but has seen triple digits on numerous occasions. Well done. Did the shop leave as checked, or did they adjust to bring clearance back to about middle of the range? RE: The OBSERVED Valve Clearance thread - Frulk_imp - 03-30-2019 Funny, I didn't even ask about that. The bill states they adjusted them. RE: The OBSERVED Valve Clearance thread - the Ferret - 03-30-2019 why two measurements for each one? ie: #1 exhaust 30...30 intake 18...18 wouldn't it measure just EX 30 .... or INT 18? If they didn't charge you for shims i would assume they didn't use any. RE: The OBSERVED Valve Clearance thread - Lord Popgun - 03-30-2019 Because our bikes have 4 valves per cylinder. RE: The OBSERVED Valve Clearance thread - peterbaron - 03-30-2019 (03-30-2019, 03:50 AM)Lord Popgun_imp Wrote: Because our bikes have 4 valves per cylinder. 2 intake 18...18...+ 2 exhaust 30...30 /cylinder
