CB77 - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Other Bikes (https://cb1100forum.net/forum/forumdisplay.php?fid=17) +--- Thread: CB77 (/showthread.php?tid=7354) |
RE: CB77 - the Ferret - 08-20-2016 Lol Go Honda LOoks and sounds good Ole How are you doing with your knee? RE: CB77 - Ole - 08-20-2016 knee is getting a little better there are days I still wish for the old knee did you notice the rubber lever thingies on the Super Hawk? RE: CB77 - the Ferret - 08-20-2016 Of course wouldn't be a proper CB without them
RE: CB77 - flynrider - 08-21-2016 Wow, Ole! It's a beauty! Nice job. RE: CB77 - redbirds_imp - 08-21-2016 Great find Ole. I like it! RE: CB77 - Cormanus - 08-21-2016 What a find. Great work Ole. RE: CB77 - Ole - 08-21-2016 It was fun getting the old girl running. All it cost was about $450 in parts. I have put 300 miles on it in the last two weeks. I am going to ask an oil question. Do I need my head examined? I want to change the oil. I have straight 30 non detergent in it now. My riding buds say use a good motorcycle 10w30 or 10w40. Would this be OK? The 1964 owners manual says SAE 30 non detergent. But detergent oil is better than it was in 1964. What should I do??? Not starting a war just want opinions,,,,,,,, RE: CB77 - flynrider - 08-22-2016 1960s air cooled engine technology was such that fit tolerances between pistons and cylinders were a bit loose and engines burned some oil by design. Burning a detergent oil left ashy deposits that accumulated in the cylinder and eventually resulted in hot spots (which could cause pre-ignition knocking). The reason I know anything about this is because air cooled aircraft engines have the same issue (most having been designed in the same era). Aircraft engines still don't use detergent oils for that reason. They use oils with an ashless dispersant that suspends contaminants in the oil, but doesn't leave ash deposits when burned. I'd probably stick with the non-detergent oil that you're currently using. While the detergent packages in oil have certainly improved over the years, modern oils are designed for engines that burn little to no oil. RE: CB77 - Ole - 08-23-2016 Thank you for that advice. I will go against my buds and stick with what the owners manual says- SAE 30 non detergent RE: CB77 - Ole - 08-31-2016 I need to run something past you guys again. On another forum, the experts said my valves were to loud. I have them adjusted to .004 which is what Honda wants. I made a new vid tell me what you guys think are they to loud? https://www.youtube.com/watch?v=QDS7Ggtpfe4 This guy is a decent shade tree mechanic (wink wink). Over coffee the other day he said they were not to loud but maybe some cam chain noise? I took the cam chain tensioner apart and it looked good.
