New to me UJM - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Other Bikes (https://cb1100forum.net/forum/forumdisplay.php?fid=17) +--- Thread: New to me UJM (/showthread.php?tid=6457) |
RE: New to me UJM - max - 06-01-2022 To check the condition of the points i test the coil side of the points/condenser with my multi meter against frame/ground. When the points are closed there should be something like 100 millivolts ( 0,1 volt ) across the points, ( how else could you tell the condition of the points? ). If there is a difference then one set needs cleaning and checking again, usually i clean mine at the beginning of every season with a small strip of fine grain wet and dry folded so that both abrasive sides make contact with the poins at the same time and drag it several times in between the points until i get the right reading. Clean points produce a clean spark. "I’m enjoying tinkering with this bike. It’s a fun project and I’m relearning a lot of stuff " And getting the enjoyment of getting it fixed in the end, priceless, nice job LongRanger! RE: New to me UJM - max - 06-01-2022 And on that happy note i watched this video; https://www.youtube.com/watch?v=gT346KIYiy0 And bought this; https://www.ebay.com/itm/282094097570?_trkparms=amclksrc%3DITM%26aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D239179%26meid%3Da2889dadc9384ef5bddd15d1b6032cf4%26pid%3D101196%26rk%3D1%26rkt%3D12%26sd%3D274903877491%26itm%3D282094097570%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2WithMLRv3%26brand%3DVessel&_trksid=p2047675.c101196.m2219&amdata=cksum%3A282094097570a2889dadc9384ef5bddd15d1b6032cf4%7Cenc%3AAQAHAAABELB59iZaq6L1SxCGLGoiBqHdpPz8nqKyKuGL1QIa0H%252B4DG8k6rgHCYF5k8I%252FvGvIvTBNpcj58QD9hy91pC8qfePAatUU%252BkZmf6rb9SyGV7lMPpoDVvRUTyuvF6Tm4UQ6DfM7JCTnFrCDSxfAsuWFZ9xWXQNsWLeAjwX1NyFU360fJ2F9ZI3yfsnyfpIzhULckjIOEbScYoWyNPiymKoEUarvLosQUIZGHSB0ydtSXViijXMN%252FwDM%252FXtqJmh95Dsj3NppE%252BiW8E9OGsJuqJekVSEGQ28vlIQlvF4KC%252BUOYlgiUuTJjM2Z2cG2ARsrRm5XOU0QIJyvvTeV3nupR1hEJc80V8bmzKDFwIVc5R37SZUk%7Campid%3APL_CLK%7Cclp%3A2047675&epid=2254331463 Had no idea this existed and; Should work on brake reservoir lids too....... RE: New to me UJM - PowerDubs_imp - 06-01-2022 Thanks for sharing Max! Just bought it on Amazon for $13 [url=https://www.amazon.com/Vessel-Megadora-Impacta-P2x100-Screwdriver/dp/B003BI8HHQ/ref=sr_1_4?crid=30MHG4NSZW4U3&keywords=VESSEL+NO.980+%2B+2X100&qid=1654177982&sprefix=vessel+no.980+%2B+2x100%2Caps%2C115&sr=8-4]https://www.amazon.com/Vessel-Megadora-I...115&sr=8-4 RE: New to me UJM - max - 06-02-2022 And this is how it works in fluent Japanese; https://www.youtube.com/watch?v=pWkz3-NcZ0Q Demonstrated on a cb750 engine; https://www.youtube.com/watch?v=ECSRXKkcPa4 This is where Youtube is so helpful. RE: New to me UJM - LongRanger_imp - 06-05-2022 That’s more like it. - Gapped and static timed the ignition points - Replaced the condenser - Replaced the spark plugs - Replaced the spark plug caps - Flushed out the fuel tank - Cleaned and WD40’d many electrical connections - Rewrapped some exposed wiring on the wiring harness Except for a little popping on decel, she’s running great again. Fun stuff! RE: New to me UJM - suhawk305 - 06-05-2022 Great repair report LR! My CB77 has a little popping on decel also, but it runs great! RE: New to me UJM - peterbaron - 06-05-2022 (06-05-2022, 07:53 AM)LongRanger_imp Wrote: That’s more like it. I would convert into e-ignition, means getting rid of point, condenser, no more adjustment, near zero failure. RE: New to me UJM - GoldOxide_imp - 06-05-2022 (06-05-2022, 08:51 AM)peterbaron_imp Wrote:(06-05-2022, 07:53 AM)LongRanger_imp Wrote: That’s more like it. I would convert into e-ignition, means getting rid of point, condenser, no more adjustment, near zero failure. Maybe just use a Raspberry Pi Zero for the custom "ECU" and get your offspring to write the code as a science project. RE: New to me UJM - LongRanger_imp - 06-05-2022 PB, good suggestion, but if I went that route, I’d also have to get rid of the tire tubes, carburetors, clutch & throttle cables, etc. They’re all potential weak points as you know and prone to failure at the wrong possible moment. In all seriousness, I’m not bothered by the ignition system. It’s easy and fun to maintain and part of what makes this bike neat to own, at least for me. RE: New to me UJM - peterbaron - 06-05-2022 Agree, these would definitely be mor important mods, good luck |
