Parts fail - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Parts fail (/showthread.php?tid=4945) |
RE: Parts fail - Bazbro_imp - 06-29-2019 I rarely use the brakes on my Beemer. So much so that it is still on the original pads and shoes... Since 1992! I've never had to change them. Mind you, I get massive engine braking (cr upped to 10.5-1) and using 'anticipation' I often just don't need to brake. RE: Parts fail - the Ferret - 06-29-2019 same brakes since 1992? that's 27 years! How many miles are on the bike?
RE: Parts fail - Bazbro_imp - 06-29-2019 Only about 50000. RE: Parts fail - Cormanus - 06-29-2019 Geez, Bazbro, the only way I could make a set of pads go that long is stop the bike by running into things. ![]() In support of LongRanger, I can change the brake pads on the CB, so anyone can. RE: Parts fail - SportsterDoc - 06-29-2019 (06-29-2019, 04:55 AM)Bazbro_imp Wrote: I rarely use the brakes on my Beemer. Anticipation is good...slowing for a traffic signal to minimize stopped time when it gets warmer here is a good thing! 105,000 miles for first pad change on previous 4 wheel vehicle and they could have gone more than 7 years...lot of highway driving. I replaced front pads on 76 CB750F once in ~40K miles...simply because I had them...not that they were needed. Tires and chains were much more frequent. RE: Parts fail - Charlie Bravo_imp - 07-04-2019 So, got the pads. I pull the old ones out, and SOB, they have fifty percent left. I put the new ones in, but kept the old ones. Won't do the fronts yet, tho. |
