Double stack- hold the cheese - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Double stack- hold the cheese (/showthread.php?tid=4284) |
RE: Double stack- hold the cheese - PowerDubs_imp - 01-18-2022 Not much motivation to touch the bike when I come in from shoveling snow.. ;P RE: Double stack- hold the cheese - 1973cb750 - 01-18-2022 17225-MJE-DB0 search these i wonder is they are bigger??? Double stack- hold the cheese - PowerDubs_imp - 01-18-2022 (01-18-2022, 12:04 PM)1973cb750_imp Wrote: 17225-MJE-DB0 search these i wonder is they are bigger??? That is how I found the shop that I had build these. They had made similar dual stack style to replace the Honda 650 stock parts and picked up 3whp if I remember correctly- without even touching the fueling. I expect good results. ![]() Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - 1973cb750 - 01-18-2022 (01-18-2022, 02:15 PM)PowerDubs_imp Wrote:(01-18-2022, 12:04 PM)1973cb750_imp Wrote: 17225-MJE-DB0 search these i wonder is they are bigger??? That is how I found the shop that I had build these. They had made similar dual stack style to replace the Honda 650 stock parts and picked up 3whp if I remember correctly- without even touching the fueling. I expect good results. ![]() Sent from my iPhone using Tapatalk these being larger i wonder if their worth it for 30$ to try not after every last tenth of a hp just wana wake it up a little RE: Double stack- hold the cheese - PowerDubs_imp - 01-19-2022 (01-18-2022, 11:05 PM)1973cb750_imp Wrote:(01-18-2022, 02:15 PM)PowerDubs_imp Wrote:(01-18-2022, 12:04 PM)1973cb750_imp Wrote: 17225-MJE-DB0 search these i wonder is they are bigger??? To put in the 650 stacks you will need to make the holes in the airbox larger to fit into the TB. If you want to leave your airbox alone- I had good luck just boring out the stock velocity stacks- http://cb1100forum.com/forum/showthread.php?tid=10300&highlight=velocity Plug and play- (but anything will requite you to add fuel). RE: Double stack- hold the cheese - 1973cb750 - 01-19-2022 do you have a picture of the inside of the air box? RE: Double stack- hold the cheese - E11even_Hunnit - 01-19-2022 Hoping the weather warms up around you soon, Josh. Would love to hear what the outcome is Double stack- hold the cheese - PowerDubs_imp - 05-03-2022 (01-19-2022, 11:11 AM)1973cb750_imp Wrote: do you have a picture of the inside of the air box? Does this count? ![]() ![]() Sent from my iPhone using Tapatalk Double stack- hold the cheese - PowerDubs_imp - 05-03-2022 A few more from today. ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - Nachodaddy - 05-04-2022 Wow, that is sweet. |
