Got These Today - Printable Version
+--- Thread: Got These Today (/showthread.php?tid=9639)
Pages: 1 2 3 4
RE: Got These Today - rboe - 09-09-2015
I bought and installed those two years ago. Went on very easy, then visually disappeared. If you lay the bike down (I did intentionally in the back yard to video how easy it is to pick up, even if you use your back instead of your legs) the case savers make a great half way pivot point for righting the bike.
Some say that they are as expensive as the cases so why bother; but you can hole these and the oil won't leak out. Can't say that about cases. Smile
RE: Got These Today - MikeOxbig_imp - 09-09-2015
(09-09-2015, 08:21 AM)Rboe_imp Wrote: I bought and installed those two years ago. Went on very easy, then visually disappeared. If you lay the bike down (I did intentionally in the back yard to video how easy it is to pick up, even if you use your back instead of your legs) the case savers make a great half way pivot point for righting the bike.
So you're saying the bars also makes it a lot easier to lift the bike back up if it's dropped? Not that I'm looking forward to dropping the bike but that's good to know, considering the CB weighs about 540 pounds (but feels like 400 pounds when riding). Is your video posted on the forum by any chance?
RE: Got These Today - GaryMNM_imp - 09-11-2015
Bummer, mine arrived in yesterday scratched. Already back in the UPS system as per return instructions and probably a good couple weeks out before I see pair II, the sequel... Undecided
(09-08-2015, 07:59 AM)redbirds_imp Wrote:
(09-08-2015, 07:07 AM)GaryMNM_imp Wrote: Very nice! I have a set coming in by the end of this week, looking forward to getting them installed.
Any caveats, warnings, suggestions, etc about the install?
Not really, it was an easy install but mind that you install the bars in proper order per instructions. I used Blue Loc-tite on the motor mount bolts as that looks like what Suzuki used originally. I also supported the motor with a scissor jack and mounted the bars one side at a time. Once both sides were installed, the motor mount bolts were set at recommended torque.
The Honda was even easier. Instructions are simple to follow.
RE: Got These Today - rboe - 09-11-2015
It's around here somewhere! Big Grin I forget where. But I suspect it was under SW Motec (sp?).
Once you lift the bike up from completely flat, the next somewhat stable position is the bike resting on the tires and case savers - and to a much reduced point: You.
At that point you can "rest", reposition if needed, and pop it vertically with relative ease.
In the video I do it all wrong by grabbing some handlebar, something in back and simply lifting the darn thing up. Very little leg muscle involved, but I'm in decent enough shape - and the case savers made it much easier. I would recommend backing your butt into the bike and using your legs as the main means to right the bike. Angel
Can't find it, but if you're on Facebook: [url=https://www.facebook.com/ron.boe.9/videos/vb.100000592719416/786900288006388/?type=3&theater]https://www.facebook.com/ron.boe.9/video...=3&theater
Taken first week of March last year, may help searching here.
