RE: Swing arm bushing failure - Randy B - 12-10-2019
(12-10-2019, 08:14 AM)syncronizator_imp Wrote: (12-10-2019, 07:18 AM)max_imp Wrote: Thanks that is a great photo and i was hoping you would post it.
What i found in my video is similar to what you show here, the bolt is obviously stationary and so is the bushing ( which is the area the wearmark shows ) the needle bearing provides the pivot for the swingarm.
The bushing is meant to be clamped in place and held inmobile by the force of the bolt compressing the frame and holding all the bushings and bearing inner races together like in a vice.
Mistakenly i am calling this inner assembly "the spacers" but i mean all parts that are directly around the bolt and held captive by it, i don't have a proper name for it.
So if that were the case there would not be any wearmarks on the bolt because nothing directly around it moves, ( this is the smoking gun proof ) the movement is on the outer races of the bearings and the inner races remain inmobile as long as the compressing force of the bolt is enough to hold all these spacers etc. captive together as one lump.
I believe when the bolt is torqued up it exerts over 3 tonnes of compression on the frame and the spacers, if the frame resists too much then not enough force is left to compress the spacers and they roll around creating the wear marks you show.
If you can measure the gap between the frame and the bushings with a feeler gauge, i think in my case it was 0.7 mm.
So to transfer more pressure to the bushings i mostly closed that gap ( with the spacer ) and as a consequence had a lot more pressure left over to clamp the bushings as the design requires rather than pull the frame together, this eliminated any play instantly as shown in the video clip.
In my case the bolt was torqued up fine but all the pressure was used to compress the frame which was quite rigid in that place because of the construction rather than the bushings.
Made a mistake in an earlier post, to clarify; the two roller bearings on the brake side stop the swingarm from moving sideways and provide pivot support, the needle bearing just lands on it's bushing in an arbitrary place and only supports lengthwise , as well as pivot support.
Look forward to your findings and let me know if i missed something, thanks for posting all the details!
I need to think about it
Now i undrstand the idea of "the spacer" implementation, but am not sure where the measurement should be taken. Tommorow after work I will buy the tool search and measure.
My todays swing arm play check:
https://youtu.be/Spw8ZUIaBog
Good Night
Good Night
RE: Swing arm bushing failure - syncronizator_imp - 12-11-2019
Yes, the bolt was torqued up when the video was taken.
I haven't bought the feeler gauge yet, after that also need to buy propper spacers.
I will probably do it on Saturday and let you know after completing the work.
RE: Swing arm bushing failure - egleaves_imp - 12-12-2019
After 19 days in the shop I finally get to pick up my bike this afternoon! They wound up replacing the entire assembly that holds the swing arm to the frame....nut, bolt, bearings and all. Best news is that Honda Care is picking up the $450 bill! I'm supposed to be getting the old parts back too, so I should be able to share pics of the failure.
RE: Swing arm bushing failure - peterbaron - 12-12-2019
(12-12-2019, 09:27 AM)egleaves_imp Wrote: After 19 days in the shop I finally get to pick up my bike this afternoon! They wound up replacing the entire assembly that holds the swing arm to the frame....nut, bolt, bearings and all. Best news is that Honda Care is picking up the $450 bill! I'm supposed to be getting the old parts back too, so I should be able to share pics of the failure.
Would like to see them
RE: Swing arm bushing failure - GoldOxide_imp - 12-12-2019
That's very good egleaves. As PB requested: Pics would be interesting.
Picked up the bike and was finally able to see the broken bolt. The bolt broke off inside the nut! This is clearly beyond normal wear and tear.
The service manager has a background in....structural inspection...something like that....we didn’t get into it. Anyway, he told Honda that it appeared to be a manufacturing defect and they took him at his word and made good on the warranty. Now they want to see the bolt. Hopefully they’ll be able to do some forensic analysis to deduce whether this was an isolated case, or there’s a broader risk.
Early on I was told I could keep the old parts, but now Honda wants them as evidence. I totally get that. I was “allowed” to take pictures of it so I staged a small photo shoot at the service desk. Sorry for the teaser, but the only way I can manage to post pics is from my work computer. Have to do it tomorrow.
RE: Swing arm bushing failure - max - 12-12-2019
So far that's a very good outcome, good communication all round and some solid work from your dealer, congrats
On that happy note i had a look at my own rear wheel alignment and took some pictures of how i did that, i was off by 2mm. to the right and adjusted that to 0mm.
There was nothing i noticed whilst riding but have felt some unease with 5mm. misalignment, the lengthwise seams in the road start to have a small effect on the steering;
https://www.youtube.com/watch?v=by7L3M8ai-0&feature=youtu.be
This only worked well on the sidestand, the centerstand was in the way of the string and was not reliable, as a shortcut you could look past the rear wheel's sides and check if they are in-line with the outside of the disk ( on the left side ).
RE: Swing arm bushing failure - syncronizator_imp - 12-12-2019
(12-12-2019, 01:12 PM)egleaves_imp Wrote: Picked up the bike and was finally able to see the broken bolt. The bolt broke off inside the nut! This is clearly beyond normal wear and tear.
Egleaves
Did you check after Honda replaced the bearings and other elements of the swing arm, is there no play?
Perhaps the new parts were produced badly and the swing arm still has a little play. You have everything new. There is an opportunity to verify it.
Normally no one checks it when buying a new motorcycle.
Yesterday evening I checked with a feeler gauge if there is a room for the shim we were talking about.
In my situation, torsion of the bolt definitely squeezes the frame, all "collars" and bearings.
Maybe I was looking wrong. However, I think that if there is slack there, the swing arm could slide on the bolt by e.g. 0.7 mm across the motorcycle (left <=> right).
This only happens when the bolt is unscrewed because the frame flexes and slack occurs.
I will try to dismantle the swing arm tomorrow.
I hope I can find the reason. Maybe I'll make a movie.
RE: Swing arm bushing failure - max - 12-13-2019
Here's the confusing part Synchronizator; my swingarm still moves sideways by a mm or so, it slides quite freely when i push and pull on the swingarm close to the hingepoint but the movement is sideways only and does not sway the swingarm out of alignment.
What ? this is the sideways play that is limited by the two roller bearings movement in their housing limited by the circlip ( no20 ) , the needle bearing is able to move sideways on it's flanged collar and that's fine.
the sideways play you want to correct has to be measured with the bolt loose to check for free play of the collars, there should be next to nothing, 0,1mm free play before the bolt is torqued up to spec. and you may have to put a screwdriver in the gap to keep the collars toghether whilst the measurement takes place.
So be sure to measure the correct ( fore and aft movement ) that is happening when you move the wheel sideways as you demonstrated in your video.
And yes, valid question for egleaves, i agree and hopefully he has some pictures of all the replaced parts for us, that would be a first and very welcome.
