My anti lock non anti lock brake - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: My anti lock non anti lock brake (/showthread.php?tid=3133) |
RE: My anti lock non anti lock brake - retroman_imp - 07-31-2013 Tried pad break-in technique (accelerate to 40 and apply rear brakes down to 10 and repeat a few times) and either it's getting better or I'm getting used to it. I will bring it up with the dealer during 1st service. RE: My anti lock non anti lock brake - the Ferret - 07-31-2013 Im heading over to my brothers house tomorrow to go up on his lift. We will pull my pads, sand them and see if that helps any. I let him ride it the other day, and he came back saying " yea, there ain't much there" lol. RE: My anti lock non anti lock brake - Lord Popgun - 07-31-2013 ferret, if your brother rides mine he is gonna say the same thing! RE: My anti lock non anti lock brake - the Ferret - 08-01-2013 Well yesterday my brother and I pulled my pads, took a mill bastard file to them, then some heavy duty sand paper in a figure 8 pattern, blew them off and reinstalled. While the pads were out, I also scotch padded both sides of the disc again. Then I took a ride and did the 45 to 15 mph rear brake only thing about 5 times. Result : It's a little better, but certainly not what I'd expect. I may stop at the dealership and let one of their techs take it for a ride and see what he thinks. RE: My anti lock non anti lock brake - Lord Popgun - 08-01-2013 ferret, I'd be interested in what they think. I'm going to have mine looked at when they replace the rear tire. RE: My anti lock non anti lock brake - CIP57_imp - 08-02-2013 I was thinking how well the brakes perform on this bike. All my recent Honda's have linked brake systems ( non abs ) and don't like any of them. Braking on linked systems hard in a turn will stand you straight up, horrible feeling. You could never low side with them. My rear brake is very good, it locks right up if i want it to allowing me to low side in case of danger. The rear brake on this bike is much better than my ST, CBR or XX all with linked brakes. My rear has a very strong bite but its new, we'll have to see when we get some miles on her. RE: My anti lock non anti lock brake - Ack-CB11_imp - 08-02-2013 Something has to be wrong. Not that it helps you stop but you should be able lock the rear wheel up at will. I have to be easy under hard braking so not to lock it up. First, I'd be suspect of air or moisture in the line some how. Then I would check out the hose, soft spot or bulgding, posible new but defective? All us non-abs riders need stainless lines. One member has them IIRC. Keep us posted
RE: My anti lock non anti lock brake - ChipBeck_imp - 08-02-2013 (08-01-2013, 10:02 PM)The ferret_imp Wrote: Well yesterday my brother and I pulled my pads, took a mill bastard file to them, then some heavy duty sand paper in a figure 8 pattern, blew them off and reinstalled. While the pads were out, I also scotch padded both sides of the disc again. Then I took a ride and did the 45 to 15 mph rear brake only thing about 5 times. Result : It's a little better, but certainly not what I'd expect. Mickey, I am certain that you have air in your rear brake system. I deal with this a lot. On my aerobatic aircraft (they use independent hydraulic disc brakes just like our bikes) that spend a lot of time inverted or at negative G's some brake brake fluid is often lost out of the vent line and that introduces air into the system which causes the brake to get very spongy, loosing 75 to 90% of it's effectiveness. The fluid is not compressible and it provides a direct link to your calipers. Any air in your system is very compressible so instead of squeezing your brake pads against the discs you are compressing that air. Glazed pads will degrade braking effectiveness but not by a ton. Air in your system does. Get out your shop manual, bleed your rear brake system, fill it with fresh fluid, and then send me a thank you note. Cheers bro. Chip RE: My anti lock non anti lock brake - the Ferret - 08-02-2013 Took my ST out for a 325 mile spin today ( rear brakes on it are awesome)....for a hotdog lol. Drove from one side of Ohio durn near to the other to meet a riding buddy for lunch at a Sonic. tried the new pretzel bun hot dog with cheese and bacon, tater tots and sweet tea. Dog was just ok, couldn't taste the bacon. Tater tots and sweet tea were great. Any excuse for a ride! I think you all might be right. It's under warranty so I will let them bleed it. RE: My anti lock non anti lock brake - Deanohh_imp - 08-02-2013 I must say you found a very good reason to introduce your aerobatic aircraft into the discussion! Is there any reason to suspect The Ferret is riding his motorcycle in an inverted position? Good thing it is fuel-injected, in that case, as gravity carbs tend to cut out under negative G's (as we all know from that opening scene in Battle of Britain). ![]() (08-01-2013, 10:02 PM)The ferret_imp Wrote: Well yesterday my brother and I pulled my pads, took a mill bastard file to them, then some heavy duty sand paper in a figure 8 pattern, blew them off and reinstalled. While the pads were out, I also scotch padded both sides of the disc again. Then I took a ride and did the 45 to 15 mph rear brake only thing about 5 times. Result : It's a little better, but certainly not what I'd expect.That's your whole problem. Should have used a pedigreed file. They are hard to find, though. I just use any of the muther......s in my tool box. |
