which tires to go with? - Printable Version
+--- Thread: which tires to go with? (/showthread.php?tid=2474)
Pages: 1 2 3 4 5
RE: which tires to go with? - the Ferret - 04-01-2016
That's crazy the other direction. Call some more places
RE: which tires to go with? - Jim21680_imp - 04-01-2016
Come on, fellas...there's supposed to be a special bond between a man and his motorcycle. Grab a few tools out of the shed and give it a try!
RE: which tires to go with? - flynrider - 04-01-2016
(04-01-2016, 10:04 AM)LongRanger_imp Wrote: I stopped at a local Honda dealer today for a quote to change the rear on my CB, using a tire I bought elsewhere. Wheel on the bike, not loose, so more labor required. $110! I nearly fell over.
Yikes! The shop I used to go to charged $30 off bike and $60 on bike. The place I recently found (a motorcycle tire shop) is $20 off and $40 on.
RE: which tires to go with? - DaSwami_imp - 04-01-2016
(04-01-2016, 10:24 AM)Jim21680_imp Wrote: Come on, fellas...there's supposed to be a special bond between a man and his motorcycle. Grab a few tools out of the shed and give it a try!
Ok hotshot, what tools are needed to change a tire? Balancing too?
Well, I broke the old beads with a c-clamp, and installed the new tires with a couple long chisels and some duct tape. True story, and it worked great. The two key aspects are leverage and protection, and that is all it is. Next time, I'll probably spend $30 bucks on real levers and some plastic protectors with the hub strings, but again, they're not a necessity.
As for balancing, my wheels didn't have weights from the factory, so I kept it that way. Lined up the red dots on the tires with the valves, and called it a day. Lead weights these days are in many cases overrated and unnecessary.
RE: which tires to go with? - uscgmac_imp - 04-01-2016
All depends on where you live. My area is one of the most expensive in the country for anything. Dealers charge about one hour labor with wheel still on bike. I can sucks up that fee once a year.
That's normal, one hour labor charge for dealer.
If you can find a indy shop around then they will do it cheaper than the dealership but not many near me
RE: which tires to go with? - LongRanger_imp - 04-01-2016
Really, I was just curious about the dealer's price. I have no problem removing my own wheels but I do take them to a shop for tire mounting. $20 off the bike seems to be fairly common around here. I nearly fell over at the $110 quote because my BMW dealer charges $75 on the bike and I think that's expensive.
which tires to go with? - Pauley - 04-01-2016
Sounds like he doesn't want your business. Move on down the road.
RE: which tires to go with? - Frulk_imp - 04-01-2016
About a month ago I paid around $72-$76 to have a rear tire mounted that I bought off the Honda Dealer here locally.
110.00 is about the hourly rate they charge and that is for still on the bike. It should be half or less if you just bring the wheel in. If it's the same shop you bought the bike at they may work with you.
