Need recommendation for throttle lock - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Need recommendation for throttle lock (/showthread.php?tid=1387) |
RE: Need recommendation for throttle lock - Jeffhorn_imp - 05-19-2017 (03-24-2016, 10:26 AM)Jim_imp Wrote: I need a recommendation for a good, not too expensive, throttle lock. That flasher switch inhibits the use of the generic one that the dealership sells. Thx I really like the KAOKO I got from Twisted Throttle. RE: Need recommendation for throttle lock - CB-Deacon_imp - 05-20-2017 I have had all the throttle locks over my 35 motorcycle career and the BrakeAWay is by far the best especially when unexpected braking happens. Touch the front brake and the lock releases. It does take up a 1/2 inch of the grip but it is worth it. RE: Need recommendation for throttle lock - Lord Popgun - 05-21-2017 I have a BrakeAway on my CB and they do work well. But not in-expensive, and are fiddley to adjust. Awesome customer service too! Since I have heated grips on my ST the BrakeAway wouldn't work. I'm trying a Throttlemeister on it. Haven't used it yet so can't really comment on using it. RE: Need recommendation for throttle lock - apex1_imp - 07-17-2018 I know this is reviving an old thread, but I thought I'd share some information. I have used Throttlemeisters for many years and I have always liked the beautiful machining and the matching bar end for the non-throttle side that comes with one. They did not have one listed for the 2017 CB1100EX (or any CB1100) but I saw online that the Kaoko listed for my CB1100 also fit some other Honda models. So I ordered a Throttlemeiester that was listed as fitting a bike that the Kaoko fits, but the inner bar mount was too large to fit, plus the throttle tube on my EX flared on the end as had some "teeth" molded in the nylon. Disappointed, I called Marker Machine (the manufacturer) to see if I needed a return authorization number and I spoke with Fred. Fred told me he had a couple slightly smaller inserts and he sent me both to try. These are precision machined parts that compress and expand when tightened, and they can't be cheap. Still, he sent me 2 more by second day mail and the larger of the 2 new parts was perfect. In addition to the slightly smaller diameter bar insert, I also had to use a Dremel to remove the nylon teeth at the end of the throttle tube so I could slip on the friction sleeve required for the device. That took all of about 5 minutes. I just mailed the 2 inserts I didn't use back to them. So if anyone is interested, they now know which parts to send for our bikes, and it fits and works. They even include a puller that can be used to pull the OEM inner bar weight on the throttle side to allow the inner bar adapter to be used. The Throttlemeister is a tiny bit finicky to set up perfectly at first, but it is really not a big deal. Once set up, it is done. I installed one on my Ducati 11 years ago and have not had to readjust anything since. I have no stake in Throttlemeister--I just like the device. RE: Need recommendation for throttle lock - 3rdbike_imp - 07-17-2018 Thank you for that information, Apex1! I too have used Throttlemeister for a long time. I'm not satisfied with my homemade attempts at a throttle lock, so I may very well contact them for a set for my EX. RE: Need recommendation for throttle lock - apex1_imp - 07-17-2018 (07-17-2018, 04:23 AM)3rdbike_imp Wrote: Thank you for that information, Apex1! I too have used Throttlemeister for a long time. I'm not satisfied with my homemade attempts at a throttle lock, so I may very well contact them for a set for my EX. If you call Marker Machine, ask to speak with Fred Fisher. He’s the one I worked with there. RE: Need recommendation for throttle lock - Nortoon_imp - 07-18-2018 I have the aluminum Go Cruise 2, but I no longer use it. Both my CB500X and CB1100 EX would not hold a constant speed in 6 gear. Something like the big transport trucks, they would slow uphill and speed downhill. Fifth gear was a little better, but that shortened my fuel range. It was handy on straight flat roads if I wanted to adjust my gear. Zip up if it was cold, zip down if it was hot. Also allowed me to shake a cramped throttle hand, but you don't need a throttle lock to do that. The real reason I stopped using it was sudden stops. It was impossible to adjust the throttle lock so it will close completely in an emergency. Slows the down-gearing and leaves the bike revving when you stop. Deer and other critters are a constant threat on the roads that I ride. But not as bad as the pickup truck that sits on a sideroad stop sign, and then decides to pull out because it's only a motorcycle. |
