Today is the Big Day for me!!! - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Today is the Big Day for me!!! (/showthread.php?tid=1253) |
RE: Today is the Big Day for me!!! - flynrider - 11-09-2018 Heat works well. I just set mine out in the driveway on a 100+ degree day and they peeled right off. The residue will come off with a solvent. I was lazy and just dipped a cloth into the tank and it wiped right off. Hopefully, with only 137 miles, it's spent the last 5 years in the garage. If so, you shouldn't have to worry too much about unfaded paint under the stickers. RE: Today is the Big Day for me!!! - Lord Popgun - 11-09-2018 And Cormanus is joking about the metal scraper. I did what Flynrider did and just used my finger nail. Since Summer is over you can use a hair dryer to heat them up. I used a WD-40 to remove the glue. Don’t use anything that would mess up paint. Then some polish and done. THEN, RLETS install you must (Read that in Yoda’s voice) RE: Today is the Big Day for me!!! - Bheezy27403_imp - 11-09-2018 (11-09-2018, 02:07 PM)Cormanus_imp Wrote: Personally I'd use a metal paint scraper. Other, more sophisticated forum members would use a hair dryer to melt the glue and then peel them off gently. There is a risk the rest of the paint on the tank may have faded so you'll see brighter spots where the labels were.
RE: Today is the Big Day for me!!! - 96gears_imp - 11-10-2018 FYI... Mine is #1325, mfg date 03/13 So... I successfully removed TANK LABELS with my wife's hair dryer and WD-40, but... The paint is MUCH darker under the labels!!! BUMMER! Here's my VIN... RE: Today is the Big Day for me!!! - the Ferret - 11-10-2018 wow that is a huge difference in color. RE: Today is the Big Day for me!!! - Houtman_imp - 11-10-2018 Where was the bike stored ? Outside ? RE: Today is the Big Day for me!!! - Cormanus - 11-10-2018 That is a bummer, 96gears. I’ve taken the liberty of adding your VIN to the forum register. RE: Today is the Big Day for me!!! - Frulk_imp - 11-10-2018 Not problem. Buy a generic tank protector that applies to the tank with adhesive and cover that up. Problem solved. RE: Today is the Big Day for me!!! - sonnyb_imp - 11-10-2018 congrats 96 on the bike, to my understanding that discoloration on your fuel tank that's only a clear coat what is changed,and hopefully just upper surface,not a red base, talk to your local,friendly body shop,very gentle sanding with water 1000-2000 sandpaper and polishing,buffeting and waxing and waxing and waxing might solve a problem,HOWEVER if you have never done it before,DON'T do it,please,first time on that fuel tank.you can always get a fender from a junk yard and try it. RE: Today is the Big Day for me!!! - flynrider - 11-10-2018 (11-10-2018, 07:56 AM)Houtman_imp Wrote: Where was the bike stored ? Outside ? I'd think it would have had to have spent some time outside. Hard to imagine that much fading without some UV rays being involved. One other fix might be to put the stickers back on. |
