OEM tires - Printable Version
+--- Thread: OEM tires (/showthread.php?tid=5637)
Pages: 1 2 3 4
RE: OEM tires - jimgl3_imp - 02-07-2016
oh, sorry for the confusion. 160 rears are fine! clearly ok on 4 inch rim, no problem. it's only the 120 front going on the 2.5 inch front rim that concerns me.
here is tech data for pirelli angel gt, which i was leaning towards until i saw this
http://www.pirelli.com/minisite/pirelli-motorcycle-tyre-guide-2015/#374/z
120/70 18 permitted rim size 3.75 !
RE: OEM tires - jimgl3_imp - 02-08-2016
received this today from Pirelli
Hello
A 120/70-17 tire is designed to fit a 3.50-3.75” rim. We must state that tires are not a universal product that can be as the consumer wants and suggested fitments by the tire manufacturer should always be followed. Hope this helps.
Pirelli Moto Consumer Affairs
800 747-3554
RE: OEM tires - jedd_imp - 02-09-2016
(12-17-2015, 02:43 AM)Paulb_imp Wrote: Just one complication here, are we all talking about spoked wheels with inner tubes because as I understand it not all tubeless tyres can be used with tubes. The reason being that tyres designed for tubes are well finished on the inner surface and don't rub on the tube, whereas tubeless tyres can have rough inner surfaces and cause punctures. My bike has tubes and I need to make sure the tyres are compatible.
That's spot on with my experience. So kudos to you for pointing out this unique situation with tubeless vs. tube tires. Tubeless tires not only have different shaped rim edge profiles, but the surface irregularities inside the tire are often unfinished, or the design doesn't call for cleaning them up, and under those conditinos, that can puncture a tube.
I've ridden w/ dual sport guys where they typically carry inner tubes even though theirs are tubeless tires. Reason being, if the sidewall gets sliced, no amount of plug is going to seal it. Thus, inner tubes have to be put inside the tubeless tire since we're in the middle of nowhere. We had a rider who kept popping his inner tube inside a tubeless tire. Come to find out, the inside of the tire was molded w/ these tiny "tits" protruding inward. We didn't know it at the time of repair, so we just put an inner tube inside it, and about 10 miles down the road, the inner tube popped. Luckily, someone else carried heavy duty tubes, so we used that, and the rider was able to complete the ride with us w/o any more punctures.
RE: OEM tires - jimgl3_imp - 03-05-2016
sport demons shod today! ride tomorrow.
RE: OEM tires - jimgl3_imp - 03-06-2016
about 80 miles today. already like them better than oem dunslop radials.
RE: OEM tires - jimgl3_imp - 03-07-2016
another 40 miles today. began to push a little. i like these tires!
RE: OEM tires - albert52_imp - 03-10-2016
(03-07-2016, 09:43 AM)jimgl3_imp Wrote: another 40 miles today. began to push a little. i like these tires!
thanks, I was glad to hear the review Huh. My Sport Demons will be here Monday
RE: OEM tires - LongRanger_imp - 03-11-2016
Those Sport Demons are bias-ply tires, not radials, correct? Is that the correct fitment for this bike?
I really liked them on my Moto Guzzi V7 Classic, but they were toast within 4000 miles. I'll be curious to know how they do under your heavier and more powerful CB1100.
RE: OEM tires - Frulk_imp - 03-11-2016
I replaced my front Sport Demon on a V7R right at 4,000 miles and the CB's OEM front tire right around 4,500 miles
RE: OEM tires - jimgl3_imp - 03-16-2016
you will find they turn in quicker than Dunlop OEMs. I haven't had Bridgestones.
yes they are bias ply and yes same fitment. if you consider the whole reason for developing radial tires, it makes little sense to have radial tires on these bikes and the tread to sidewall ratio makes no sense for a radial.
