Chain Slack Adjustment...Am I Paranoid? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Chain Slack Adjustment...Am I Paranoid? (/showthread.php?tid=4771) |
RE: Chain Slack Adjustment...Am I Paranoid? - Gone in 60 - 07-29-2020 Anti clockwise, in the direction of tightening them. Mind you, just a snug with the 8mm nut driver, not applying any real force. Just enough to eliminate any vibration. RE: Chain Slack Adjustment...Am I Paranoid? - Cormanus - 07-29-2020 Thanks mate. RE: Chain Slack Adjustment...Am I Paranoid? - Gone in 60 - 07-30-2020 Well, not sure what I did wrong the first time, but got to work (another 13 miles after last night's adjustment), and checked, and the adjustment and alignment held. I'll check again when I get home, and if it hasn't moved, I'll consider the loosening a fluke. Chain Slack Adjustment...Am I Paranoid? - Pauley - 07-30-2020 (07-29-2020, 08:39 AM)Cormanus_imp Wrote: Pauley, can you expand on your advice, please? Do you tighten the adjuster bolts clockwise or anti clockwise? The manual says to do it, but I’m never sure which way. The chain slack adjust screws have reverse thread; why I don’t know. To tighten the chain or to snug the adjust screws against the axel at the last step I described, you turn counterclockwise. RE: Chain Slack Adjustment...Am I Paranoid? - Cormanus - 07-30-2020 Thanks, Pauley. I hadn’t thought about it, but the reverse thread is odd. RE: Chain Slack Adjustment...Am I Paranoid? - Gone in 60 - 07-30-2020 That’s why I marked the end of the handle of my nut driver, so I wouldn’t have to remember that lefty isn’t loosey here. RE: Chain Slack Adjustment...Am I Paranoid? - Haystack_imp - 07-31-2020 Must be habit. Back in "the day" our dirt bike chains would tighten up when we sat on them as the two sprockets would align with the swing arm pivot shaft and produce maximum distance between the sprockets. Following the published procedures is the way to go. |
