peg feelers - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Accessories/Modifications (https://cb1100forum.net/forum/forumdisplay.php?fid=8) +--- Thread: peg feelers (/showthread.php?tid=8434) Pages:
1
2
RE: peg feelers - zirconxi_imp - 03-15-2020 Was actually looking for information on maximum lean angle of CB1100 and found this thread instead. For my standard 2013 bike, the bike can lean to about 44-46 degree only, peg feelers can grind till about 30mm before the next thing on bike start to touch the ground. On left side, side stand will start touching the ground, on right side, the frame will be touching the ground. Please be extra careful, as peg feeler will retract and cause less riding dynamic disturbance, but if you start touching side stand on left or frame on your right, you will either get sudden left pull (side stand drag) or front lift (frame touch ground lift of front wheel). Exhaust wouldn't touch ground till the front wheels is off the ground. But I believe the pre-load setting might change these as the front or back might be higher/lower depending on setting. (10-16-2019, 08:53 PM)shap_imp Wrote: appreciate it guys...little embarrassed i hadn’t actually gotten down that low and realized it. for those of you who have done it, do you know what makes contact next? the centerstand? the pipe. |
