Strange Issue with Key - Printable Version
+--- Thread: Strange Issue with Key (/showthread.php?tid=5830)
Pages: 1 2 3 4
RE: Strange Issue with Key - Stealth128_imp - 10-12-2014
Yes the locksmith knew what to do he has a buffing wheel that removed the small sharp edges from when Honda cut it actually he has a Honda Silverwing with the same issue. Hope this helps.
RE: Strange Issue with Key - metallyguitarded_imp - 10-12-2014
(10-12-2014, 02:31 PM)Stealth128_imp Wrote: Yes the locksmith knew what to do he has a buffing wheel that removed the small sharp edges from when Honda cut it actually he has a Honda Silverwing with the same issue. Hope this helps.
Thanks brother. I'll let you (and everyone) know if this does the trick!
RE: Strange Issue with Key - kmoney_imp - 10-12-2014
Mine will do this when you lock the steering as well. I've found that all I need to do is push the bars a slight bit to the left as i turn the key -- just to relieve the small amount of tension on handlebar-key lock mechanism. On all my cars, if there is side-to-side pressure on the front tires when parked with the wheel lock on, I have to do the same with the steering wheel. Always thought it was the normal.
RE: Strange Issue with Key - Pterodactyl_imp - 10-12-2014
Me too. Bent the key in the usual seat lock fiasco, straightened it by hammer (as carefully as possible or else I was facing a day or two in downtown Kyogle) so that it worked. Workable but not smooth so I now use the other (spare) key and use the first as backup. And, yes, as others have remarked, the steering lock pressure needs to be removed before unlocking and turning the ignition on. A squirt of lubricant down the keyhole also is beneficial.
(10-12-2014, 02:54 PM)kmoney_imp Wrote: Mine will do this when you lock the steering as well. I've found that all I need to do is push the bars a slight bit to the left as i turn the key -- just to relieve the small amount of tension on handlebar-key lock mechanism. On all my cars, if there is side-to-side pressure on the front tires when parked with the wheel lock on, I have to do the same with the steering wheel. Always thought it was the normal.
I get what you're saying but my issue is somewhat different. It didn't happen until after I had used the lock. Ever since then, with the handlebars unlocked, the wheel straight, the key struggles to go in, doesn't want to turn at all and is a bear to get back out. I have to put it in, wiggle it around, pull it out some where it resists as if it's actually stuck in the ignition, then I can turn it. Half of the time. My other key, seems to be working fine. I'm going to try the locksmith route and cross my fingers that it's more of a key issue than an ignition mechanism issue.
RE: Strange Issue with Key - jsinher3_imp - 10-12-2014
(10-12-2014, 07:18 AM)metallyguitarded_imp Wrote: Yesterday when I parked my bike, I locked the handlebars for the first time - bars to full left, push in key, turn to the left, remove. Worked as expected. When I went to unlock, the key had trouble going in. Then it wouldn't turn. Then I got a lot of resistance pulling the key out. I tried four or five times and each time, it wouldn't turn. The top of the ignition slot spun 180 degrees with just the tip of the key inside. I turned it back and put the key in all the way. Again, no go. After fiddling with it for a minute, I finally got it to unlock and start the bike. Everything else seemed fine. Before using the lock, the key would go in and turn as expected. Any ideas what that's all about?
Today, I tried the "spare" key and it seems to be working fine. The key I was initially using continues to give me problems. Really weird. I hope there's nothing inside the mechanism that's chewing up the keys. I'll ride with this key for a while and see if the problem persists. Stay tuned ...
i noticed the ignition slot on my cb keyhole does the same thing
RE: Strange Issue with Key - Henrik_imp - 10-13-2014
Could somebody have tampered with the lock while you were away? I know i have had issues twice already with possible attempted theft, and the key cylinder then having problems.
RE: Strange Issue with Key - metallyguitarded_imp - 10-13-2014
(10-13-2014, 12:52 AM)Henrik_imp Wrote: Could somebody have tampered with the lock while you were away? I know i have had issues twice already with possible attempted theft, and the key cylinder then having problems.
Wow, I didn't even consider that. I guess that's a possibility. Although it doesn't explain why one key works fine and the other doesn't. I was parked in a rather conspicuous space where someone messing with the bike would have been obvious. Then again, most people would probably figure whoever was messing with it, owned it. I don't think that's it but you got me thinking.
Were I live it is so common it is usually the first thing I check. Geneva, Switzerland, is just next to the French border, and we get these crews with a mini van that come from Lyon in France. Often they just stop behind a bike, a couple of guys get out, lift up the bike and put it in the back. Within five minutes they are gone over the border. I had a 6 month old VFR800 stolen that way at 5PM in the city center in front of my office. Luckily we have good insurance...
RE: Strange Issue with Key - ClassicVW_imp - 10-13-2014
If you have another good key, go to a quality locksmith and have him make you one or two.
On my ride home when I bought my CB, there were two of the nice factory keys on the key ring, one being in the ignition of course. When I arrived home, the other key was gone from the ring! If it didn't happen to me I wouldn't have believed it was possible. So I went to the locksmith and he made me a key. It went in allright, but I had to convince it to turn the ignition. I went back and he said to ride the bike over. I did and he made another key and tried it and went back and used the buffing wheel a couple of times. Only then did it work smoothly, but like I said, I need to put it in exactly straight. I'm convinced that is the lock's issue, not the key's.
(10-13-2014, 01:10 AM)Henrik_imp Wrote: Were I live it is so common it is usually the first thing I check. Geneva, Switzerland, is just next to the French border, and we get these crews with a mini van that come from Lyon in France. Often they just stop behind a bike, a couple of guys get out, lift up the bike and put it in the back. Within five minutes they are gone over the border. I had a 6 month old VFR800 stolen that way at 5PM in the city center in front of my office. Luckily we have good insurance...
In my police career, every motorcycle theft I responded to (there weren't all that many really) the bike was stolen by 3 guys who pull up in a pickup truck at night and lift it in and are gone in a minute.
