Dyno tuning oil level - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Dyno tuning oil level (/showthread.php?tid=5716) Pages:
1
2
RE: Dyno tuning oil level - Motogeezer1949_imp - 10-18-2015 96.1 rwhp after dyno tuning. RE: Dyno tuning oil level - Brookland27_imp - 10-18-2015 (10-17-2015, 01:40 PM)Streetshark07_imp Wrote: I got it done and, as expected, only actually gained about 1 horsepower, but being that it isn't running lean anymore, the machine isn't wishy-washy like it used to be. So, verdict: If you have disposable income, spend about another grand making this machine what it should've been to start with. If you don't have disposable income, then why would you buy a machine like this one in the first place. Now I just need some Michelin tires, anybody have the just right sizes for PR3's for this bike? WHat exhaust are you running? 1hp gain from before the tune or from a stock bike? Can you post an image of your dyno run? What were your output numbers RE: Dyno tuning oil level - AzBob_imp - 10-19-2015 (10-17-2015, 01:40 PM)Streetshark07_imp Wrote: I got it done and, as expected, only actually gained about 1 horsepower, but being that it isn't running lean anymore, the machine isn't wishy-washy like it used to be. So, verdict: If you have disposable income, spend about another grand making this machine what it should've been to start with. If you don't have disposable income, then why would you buy a machine like this one in the first place. Now I just need some Michelin tires, anybody have the just right sizes for PR3's for this bike? If I understand correctly, you spent $1,000 to gain one horsepower? If that's the case, I would gain much more performance by simply losing 20lbs of body weight (which I need to do, regardless), and that wouldn't cost me a dime. RE: Dyno tuning oil level - Streetshark07_imp - 10-19-2015 The main thing I got out of this is making the bike not run lean anymore, its manners are much improved. I'll post a scan of the dyno when I can get around to it... RE: Dyno tuning oil level - Streetshark07_imp - 10-25-2015 AZbob, I'm guessing that the Honda quoted horsepower is at the crank whereas mine is at the rear wheel. All I know is that the bike runs a lot better now. Also, this dyno was done in Hawaii where it's always hotter than dam*it and the humidity is just as high -StreetShark |
