Amsoil Recommendation - Printable Version
+--- Thread: Amsoil Recommendation (/showthread.php?tid=5710)
Pages: 1 2 3 4
RE: Amsoil Recommendation - Short Timer_imp - 08-26-2014
This is all so confusing Sad
RE: Amsoil Recommendation - Pterodactyl_imp - 08-26-2014
Did someone think there was no sense of humour on this forum? There's more laughs per line in an oil thread than even a tyre thread, or, believe it or not, a header cleaning thread.
Cheers, and remember, stay well-oiled.
RE: Amsoil Recommendation - lukeduck_imp - 08-26-2014
5-80 wt. full synthetic Snake Oil, anything else will destroy the engine, plus you only have to change it every 50,000 smiles. What was that about lack of humor? Now can we discuss chain cleaning?
Amsoil Recommendation - Cormanus - 08-26-2014
Snake oil!? Come down under, mate. We have Goanna oil which never needs changing.
Goanna oil, seems I recall that stuff from the distant past. Seems it only worked south of the equator, on the north side it tended to seep through any and all gaskets. Other thing was that if you tried to mix it with vodka you would get a hankering for shrimp on the bar-b and start thinking of going on ride about. Coramanus, please check records and see if my addled brain cell is working properly. Meanwhile keep on riding.
RE: Amsoil Recommendation - The Spaceman_imp - 08-27-2014
(08-26-2014, 06:39 AM)Randy B_imp Wrote:
(08-26-2014, 05:24 AM)The Spaceman_imp Wrote:
(08-26-2014, 04:58 AM)Mr Jangles_imp Wrote: As far as additives for these new synthetics is probably not a good idea as a lot of chemistry went into the manufacture of these oils.
Why try and change what they created?
That's a great question Mr. Jangles. You see, Bardhal's exclusive chemical formulas sink deep deep down into your engine's metal and seals, providing molecular-level surfactant action beyond what any conventional or synthetic oil can achieve. With Bardahl, you'll ride with confidence knowing that you've poured in real engine repair and maintenance, right from the Bardahl bottle.
So you are telling us that Bardahl is a soap? Huh
Move along sir, you're crowding out the customers. There's nothing to see here.
RE: Amsoil Recommendation - Randy B - 08-27-2014
"Surfactants are compounds that lower the surface tension (or interfacial tension) between two liquids or between a liquid and a solid. Surfactants may act as DETERGENTS, wetting agents, emulsifiers, foaming agents, and dispersants."
Big Grin Beer
RE: Amsoil Recommendation - Short Timer_imp - 08-27-2014
Big Grin Beer
Big Grin Beer
Uh huh, soap.
Big Grin Beer
Big Grin Beer
Uh huh, soap.
Big Grin Beer
Uh huh, soap.
It's called stirring the pot. Big Grin
RE: Amsoil Recommendation - rboe - 08-28-2014
Burma Shave......
