forkbrace? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: forkbrace? (/showthread.php?tid=5642) |
RE: forkbrace? - Southwend - 05-19-2015 (05-18-2015, 11:58 PM)Toddman_imp Wrote: I too experienced this small wobble that you feel. At about 70mph is when I felt it. I'm going to check the steering bearings torque and will post back. now isn't that interesting. RE: forkbrace? - veech_imp - 05-19-2015 The best solution for this problem is....RLETS! They will cure all that ails your bike.
RE: forkbrace? - Toddman_imp - 05-19-2015 Also, I've been riding sportbikes for quite a while and I may not be used to the weave. Many sportbikes don't exhibit this characteristic as the triples and headstock are massive and strong. The frames are box aluminum and wrap around the engine. The CB frame cradles the engine and is of a tube design. I didn't notice an instability, it just felt different. The front fender is a fork brace of its own and will help considerably. I'm not sure that an additional fork brace will change this feeling. Things to check: Engine mount bolts, Head stock, swingarm bolts. Any or all of these will cause a weave. RE: forkbrace? - Southwend - 05-19-2015 (05-19-2015, 01:04 AM)Toddman_imp Wrote: Also, I've been riding sportbikes for quite a while and I may not be used to the weave. Many sportbikes don't exhibit this characteristic as the triples and headstock are massive and strong. The frames are box aluminum and wrap around the engine. The CB frame cradles the engine and is of a tube design. I didn't notice an instability, it just felt different. The front fender is a fork brace of its own and will help considerably. I'm not sure that an additional fork brace will change this feeling. I need a cook book for this bike because I am sure you are requiring a series of torque wrench specifications. Makes sense though RE: forkbrace? - DAC - 05-19-2015 I asked the guy that does tires for me this question and he says for this bike - definitely do a fork brace. The triple clamps aren't beefy enough as is. I'll be pricing one here soon. Gee - wonder if Superbrace has a discount for members? RE: forkbrace? - aschem_imp - 05-19-2015 Used a fork brace on my Buell and KAW W650, so far, I do not feel the need for a fork brace on my CB. RE: forkbrace? - Novice_imp - 05-19-2015 (05-19-2015, 03:36 AM)DAC_imp Wrote: I asked the guy that does tires for me this question and he says for this bike - definitely do a fork brace. The triple clamps aren't beefy enough as is. I'll be pricing one here soon. Gee - wonder if Superbrace has a discount for members? Dac, Do you know what his reasoning is? I'm curious why he thinks the triple clamps aren't beefy enough. RE: forkbrace? - DAC - 05-19-2015 (05-19-2015, 10:07 AM)Novice_imp Wrote:(05-19-2015, 03:36 AM)DAC_imp Wrote: I asked the guy that does tires for me this question and he says for this bike - definitely do a fork brace. The triple clamps aren't beefy enough as is. I'll be pricing one here soon. Gee - wonder if Superbrace has a discount for members? Dac, Do you know what his reasoning is? I'm curious why he thinks the triple clamps aren't beefy enough. So Ryan told me that the triple clamps on sportbikes and others that see significant load often come from the factory with the fork contact areas around 2"+ long with maybe two or three pinch bolts. The CB has about 1" with one pinch bolt and the triple tree just isn't that beefy. He wasn't digging at the bike and he wasn't trying to sell me anything. Just telling me that, in his experience, it would be a big help. The guy has had about one of every bike ever made and worked on the rest. So he probably knows. Novice, since your in Central Ohio, Ryan installs tires pretty reasonably. Just let me know. RE: forkbrace? - Novice_imp - 05-19-2015 Thanks! RE: forkbrace? - Southwend - 05-19-2015 So best case is it really helps, worst case is I am out $165.00. Your Honor, I rest my case. |
