Air compressor question - Printable Version
+--- Thread: Air compressor question (/showthread.php?tid=4999)
Pages: 1 2 3 4
RE: Air compressor question - DBM_imp - 03-12-2019
(03-12-2019, 04:29 AM)pekingduck_imp Wrote: If all you want is to fill tires and blow stuff clean, a pancake one like Retsel says is fine. They don't take up much space so you can stuff them anywhere, even carry them in your car easily. And you can carry them out to the street to fill your car tire.
The tradeoff is that the small 3-gallon tank means that it has to cycle on/off more often, inconvenient if you are doing a lot of painting, use air tools constantly, or have an air lift.
Less than $50 with coupon:
https://www.harborfreight.com/air-tools/air-compressors/3-gal-13-hp-100-psi-oil-free-pancake-air-compressor-60637.html
I have this same model. I use it for my 23 guage pin nailer at work, and light duty work around the house. It works great. Do not follow the break in procedure suggested in the manual. My first one died shortly after running it wide open for 30 minutes as per the manual. Swapped it out, and used the new one normally without issue.
RE: Air compressor question - Lord Popgun - 03-12-2019
DBM, the specs on yours are the same as the one he has. If he wants a little more, when I clicked on the harborfreight link for the one you have, they show a 2hp 8 gal compressor for $119. That would air a tire ok Smile
RE: Air compressor question - GoldOxide_imp - 03-12-2019
Just need to [url=https://www.homedepot.com/p/RYOBI-18-Volt-ONE-Lithium-Ion-Cordless-Dual-Function-Inflator-Deflator-with-1-1-3-Ah-Battery-and-1-18-Volt-Charger-P731KN/305986947]inflate tires only?
RE: Air compressor question - Rossi_imp - 03-12-2019
I have a small Dewalt pancake compressor that works well for everything I need it to do including running a die grinder and impact. I like it since it is easy to store and you can carry it and not have to drag out long air hoses.
RE: Air compressor question - Cormanus - 03-12-2019
I use an ancient manual thing. An early model of this, https://www.topeak.com/global/en/products/floor-pumps/1078-joeblow-pro-x
RE: Air compressor question - Rocky_imp - 03-12-2019
(03-12-2019, 12:07 PM)GoldOxide_imp Wrote: Just need to [url=https://www.homedepot.com/p/RYOBI-18-Volt-ONE-Lithium-Ion-Cordless-Dual-Function-Inflator-Deflator-with-1-1-3-Ah-Battery-and-1-18-Volt-Charger-P731KN/305986947]inflate tires only?
You mentioned this item in another thread and I've been thinking strongly about getting one.
Bill Gardner on Motoring TV also recommended one.
If I recall you recommended a better battery bought separately.
What battery was that?
I have used [url=https://www.homedepot.com/p/RYOBI-18-Volt-ONE-Lithium-Ion-4-0-Ah-LITHIUM-High-Capacity-Battery-2-Pack-P122/204321540]these P122 batteries with great long term success and I have lost none. This is the 4Ah version. I recently saw a 6Ah version is now available.
As an example of power: I use the 4Ah battery to blow leaves and get about 25 minutes of use. The leaf blower consumes a vast amount of energy. In contrast, the tire pump combo, drill, weed whacker, fans, LED work lamps, etc. will work for a very long time in comparison to the leaf blower.
RE: Air compressor question - redbirds_imp - 03-12-2019
I have a "pancake" compressor for my nail gun, truck and car tires but I use an old fashion bicycle style pump for the motorcycles. I can bring a low bike tire up to pressure with the hand pump in less time than it takes to drag out the other.
RE: Air compressor question - peterbaron - 03-12-2019
This is what I have, from Costco, Ok for small works....
https://www.costco.ca/Crisp-Air-Pro-Series-Twin-Stack-Compressor.product.100344384.html
Thanks for the battery info GO Thumbs Up Thumbs Up
I'm pretty sure I'll be getting one of those inflators Tongue
