Camshaft, camshaft cap, wear and oil viscosity - Printable Version
+--- Thread: Camshaft, camshaft cap, wear and oil viscosity (/showthread.php?tid=4930)
RE: Camshaft, camshaft cap, wear and oil viscosity - Lord Popgun - 08-05-2019
And the torque for the cam caps (or camshaft holders per the manual) the torque for the bolts is 9 ft lbs (or 12 Nm). Apply engine oil to the threads and seating surfaces of the camshaft holder bolts.
NOTICE (this is in big block letters). Failure to tighten the camshaft holder in a crisscross pattern might cause a camshaft holder to break.
And as Pekingduck said, the caps must be in the correct locations. They are marked.
RE: Camshaft, camshaft cap, wear and oil viscosity - pekingduck - 08-05-2019
(08-05-2019, 05:25 AM)Lord Popgun_imp Wrote: And the torque for the cam caps (or camshaft holders per the manual) the torque for the bolts is 9 ft lbs (or 12 Nm). Apply engine oil to the threads and seating surfaces of the camshaft holder bolts.
Honda torque specs are clean and dry, not with oil or any lubricant. If you use oil, torquing a bolt to spec will be about 35-40% higher than recommended.
RE: Camshaft, camshaft cap, wear and oil viscosity - Cormanus - 08-05-2019
10W-40 oil is fine for warmer climates according to the Owner’s Manual.
That may be Pekingduck, but that is what the service manual says. I don’t make this stuff up Smile
Some fasteners have notes to use oil or thread locker, etc.
(08-05-2019, 08:50 AM)Lord Popgun_imp Wrote: That may be Pekingduck, but that is what the service manual says. I don’t make this stuff up Smile
Popgun, you are indeed right! I stand corrected. But put oil only on those threads and the oil filter threads.
(08-05-2019, 07:52 AM)Cormanus_imp Wrote: 10W-40 oil is fine for warmer climates according to the Owner’s Manual.
And correct, 10w-40, but no heavier.
RE: Camshaft, camshaft cap, wear and oil viscosity - zirconxi_imp - 08-05-2019
Thanks for the info guys. Guess i have to open up the top again to re-torque to spec and drain out the heavy oil n put some lighter oil in. Any some pretty interesting facts on the half moon on the side of the cylinder head. I always thought its for decoration purpose. Hahaha...
RE: Camshaft, camshaft cap, wear and oil viscosity - Jurlie_imp - 08-12-2019
Honda torque specs are clean and dry, not with oil or any lubricant. If you use oil, torquing a bolt to spec will be about 35-40% higher than recommended. Just checked my copy of the Service Manual. The popgun's text I've highlited as bold is literal quote from the Manual.
