Vibrating after new tires - Printable Version
+--- Thread: Vibrating after new tires (/showthread.php?tid=4761)
RE: Vibrating after new tires - pekingduck - 08-20-2020
(08-20-2020, 05:15 AM)Jonny D_imp Wrote: I haven’t checked the bike up to speed on the center stand as it has a safety that shuts the bike off if you put it in gear while on the stand. I’ll have to check for proper chain tension thanks!
It does that on the sidestand, not the centerstand (unless sidestand is also down).
RE: Vibrating after new tires - Jonny D_imp - 08-20-2020
I didn’t know that I’ll give that a try! Thank you
RE: Vibrating after new tires - Jonny D_imp - 08-22-2020
Great tip, I ran the bike when on the center stand and it does look like the rim isn’t perfectly straight so I’ll have to look into that some more, thanks again!
