Fuel stablizer compare video - Printable Version
+--- Thread: Fuel stablizer compare video (/showthread.php?tid=4713)
RE: Fuel stablizer compare video - pekingduck - 10-31-2020
(10-31-2020, 03:08 PM)Cormanus_imp Wrote: pekingduck, is your experience with E10 or higher or regular gasoline?
E10 which is all you can buy in California. Back 10-15 years ago, there was a lot of problem with fuel going bad very quickly, in a month or two. Lawnmowers and other small engines were greatly affected and the fuel formulations seem to have improved greatly.
It now seems that fuels are lasting longer by comparison, but in situations where I won't use a bike for a month or two, I will still add some Seafoam.
RE: Fuel stablizer compare video - redbirds_imp - 10-31-2020
Fuel without E10 is becoming easier and cheaper to get in Georgia. Two years ago there were only two places selling it locally and at nearly twice the cost of E10. Now there are several locations with signs out front, "We have ethanol free", and the price is down. I use the ethanol free in all my small motors now.
RE: Fuel stablizer compare video - tj_gee_imp - 11-01-2020
You can check http://www.pure-gas.org to see where you can get ethanol free gas.
Some of the places near me are old listings that I need to get around to submitting changes for.
RE: Fuel stablizer compare video - peterbaron - 11-01-2020
This does not guarantee ethanol free in Canada.
One may enquire at particular gas station, as the operators may order it or not.
Depending on a local law, a pump may carry "ethanol free" sticker.
Seen some pumps with E/F stickers in Ontario.
I know it is confusing.
https://driving.ca/auto-news/news/why-you-dont-actually-want-ethanol-in-your-gas-tank
RE: Fuel stablizer compare video - the Ferret - 11-04-2020
I dont know. Been a satisfied Seafoam user for years. Plan on winterizing leaf blowers, chainsaw, weed whacker, riding mower , push mower this weekend. Will be using fresh gas and Seafoam again as I have for many years, and trust they will start and run fine in the spring. I also put it in my bikes a couple times a year, but each bike never sit more than a few day a year, but if I had to put one up for an extended period of time I'd use Seafoam in it.
My ATV with snow plow was used once this past winter which means it sat from maybe February 2019 until today having only been used once. It had Seafoam in it, and was on a battery tender jr the whole time. Got it out today just to see if it would start with winter coming up, and it started right up and ran fine. Ran it up and down the road a couple of times, topped off the gas, added 4 oz of seafoam, and put it back on the trickle charger hoping I dont have to use it more than once this coming winter too.
RE: Fuel stablizer compare video - PowerDubs_imp - 11-04-2020
I've had both cars and bikes literally sit for years on just pump gas- no additives- and start right up and run fine.
Granted- fuel injected.
It is the carbs that give troubles in my experience.
RE: Fuel stablizer compare video - GoldOxide_imp - 11-04-2020
(11-04-2020, 01:05 PM)PowerDubs_imp Wrote: I've had both cars and bikes literally sit for years on just pump gas- no additives- and start right up and run fine.
Same here, but carb-based lawn mower. Mind you, it is a Honda lump. It just starts in the first to third pull after a long, hard, cold Canadian winter outdoors. This year it started on the first pull. No extra fuel preserve. The fuel sits in the tank all winter. Heck, I even changed the lawn mower oil the first time in three years. The oil "looked" good, but I changed it nevertheless. It gets about 25 hours of use per year.
All other outdoor equipment is battery operated.
I never winter-store the motorcycles or cages.
