rear signal assembly - Printable Version
+--- Thread: rear signal assembly (/showthread.php?tid=4626)
RE: rear signal assembly - PowerDubs_imp - 03-17-2021
I've had good luck with Revzilla- https://www.revzilla.com/oem/honda/honda-61311-mgc-a70-stay-headlight
You don't need the spacers...I took them off mine!
[Image: 6a50004dc51902446ebb310da1e44389.jpg]
[Image: 5f6d8f03066b6c24c82f0afbf64b1578.jpg]
RE: rear signal assembly - GoldOxide_imp - 03-17-2021
Dubs - you keep teasing the Forum audience with those oh-so-good poses.
RE: rear signal assembly - cj599_imp - 03-17-2021
Couldnt get mine to fit with out them you have the larger signals it appears
rear signal assembly - PowerDubs_imp - 03-18-2021
As far as I know, the stems / mounts are the same. My bike came with the smaller signals originally.
(03-17-2021, 01:34 PM)GoldOxide_imp Wrote: Dubs - you keep teasing the Forum audience with those oh-so-good poses.
It’s going to look a whole lot better later this summer. [Image: 5e5f8456f4c64646b3e67c8f376697e3.png]
RE: rear signal assembly - cj599_imp - 03-19-2021
The inner part of the stem is bigger than the hole so i gave up and just installed the spaces o well
