Hit a Massive Pothole - Need New Wheels - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Hit a Massive Pothole - Need New Wheels (/showthread.php?tid=4465) Pages:
1
2
RE: Hit a Massive Pothole - Need New Wheels - peterbaron - 11-30-2021 We deal with bent automotive mags very often, especially during winter season, and usually with a set of two from one car, either two front or side ones. Then, we send them to a repair company...and when these come back, we put repaired and brand new beside each other....without seeing any difference, just an amazing repair. Not cheap thou. RE: Hit a Massive Pothole - Need New Wheels - michael1954 - 11-30-2021 (11-28-2021, 07:29 AM)jasonsargonautalis_imp Wrote: Howdy all, I am replacing the front wheel on my 2014 DLX at Christmas. It has some corrosion on it from sitting for 6 years. It is not terrible, and may be removable, but I am putting the bike back to new. Bought the new front wheel months back, still in the box. Just waiting for my 29 day break at Christmas to swap out the wheels. Not sure if it would fit your bike, but it holds air just fine. I can send you pictures if you think you want it and it would fit. I am going to list it on Craigs list eventually for $150 (+ shipping). ![]() Blow-up the front wheel on the DLX and you can see the corrosion. It s a thin band near the inner side of the rim. RE: Hit a Massive Pothole - Need New Wheels - Cormanus - 11-30-2021 peterbaron, I hit a pothole one rainy night totalling one low-profile mag rim and damaging another. The damaged one was repaired and cost a great deal less than replacing it. I recall the cost of a replacement was north of AU$1,000. In the end I couldn't get one at all and replaced all 4 with a second-hand set which cost less than one new rim. As it is likely the rim was damaged only because it was low profile, the replacements were not. Low profile, that is. Indeed, I wondered then, and still do, why one would have low-profile tyres for normal use given that, whether we like it or not, the occasional pot hole is a fact of life. RE: Hit a Massive Pothole - Need New Wheels - GoldOxide_imp - 11-30-2021 (11-30-2021, 01:59 PM)Cormanus_imp Wrote: peterbaron, I hit a pothole one rainy night totalling one low-profile mag rim and damaging another. The damaged one was repaired and cost a great deal less than replacing it. I recall the cost of a replacement was north of AU$1,000. In the end I couldn't get one at all and replaced all 4 with a second-hand set which cost less than one new rim. As it is likely the rim was damaged only because it was low profile, the replacements were not. Low profile, that is. Indeed, I wondered then, and still do, why one would have low-profile tyres for normal use given that, whether we like it or not, the occasional pot hole is a fact of life. ... because it is hip? ![]() [url=https://en.wikipedia.org/wiki/Tupac_Shakur] RE: Hit a Massive Pothole - Need New Wheels - peterbaron - 11-30-2021 We rarely service customers of "customized" mags with low profile tires. Many cars/SUVs today are already fitted with lower profile OEM tires than a decade ago due to variety of safety and handling factors, rather than fashion or customer desire. RE: Hit a Massive Pothole - Need New Wheels - Charlie Bravo_imp - 12-01-2021 After I hit that pothole, I drove my wife's Honda CR-V for a couple of weeks, which had normal tires and the larger sidewall just shrugged off potholes left and right. RE: Hit a Massive Pothole - Need New Wheels - jasonsargonautalis_imp - 12-01-2021 (11-30-2021, 01:43 PM)michael1954_imp Wrote:(11-28-2021, 07:29 AM)jasonsargonautalis_imp Wrote: Howdy all, Unfortunately I have a 2013 Std. and I don't think those rims are compatible. IIRC the axle size is different. Thanks for the offer though! RE: Hit a Massive Pothole - Need New Wheels - pekingduck - 12-01-2021 I believe Houtman's wheels are for a 2013 ABS model, which is compatible with the 2013-2014 ABS models. The non-ABS may be different due to having the ABS pulser ring under the disc. All front axles 2013-2017 US models are the same. The 2013 rear has a larger axle. RE: Hit a Massive Pothole - Need New Wheels - Raceman_imp - 12-09-2021 I think I would take them to a reputable wheel repair shop. They don't appear to be hurt too bad. |
