Double stack- hold the cheese - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Double stack- hold the cheese (/showthread.php?tid=4284) |
RE: Double stack- hold the cheese - Rox_imp - 09-19-2021 103rwhp and 75ft lbs? That's about what I got with the Guhl tune, open airbox and a full exhaust. Weird how tunes are illegal but bigger throttlebodies isn't. Double stack- hold the cheese - PowerDubs_imp - 09-20-2021 Define open airbox? Did you remove the airbox, did you do anything with the stock velocity stacks? These are still stocked throttle bodies, I am just switching out the velocity stacks for a new design. I would like to see your dyno chart if your numbers are close to what I achieved. I haven’t seen anyone else show that they have hit 100whp yet. Did you do it on the Dynojet? Do you have the actual run file? if so I can do an overlay Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - E11even_Hunnit - 09-20-2021 In 4 dyno numbers as well... I too, thought I was easily at the 100WHP mark with Guhls/Exhaust/TSR air funnel, until I found out that PD(with cams) is barely breaking 100HP himself with his setup
RE: Double stack- hold the cheese - Rox_imp - 09-20-2021 (09-20-2021, 05:29 AM)PowerDubs_imp Wrote: Define open airbox? Did you remove the airbox, did you do anything with the stock velocity stacks? Open airbox as in a de snorkel and a slight mod to the venturi opening in the box. Just gives a less restrictive flow of air. These bikes (most Honda 4s) don't like pods and were designed for an airbox. RE: Double stack- hold the cheese - PowerDubs_imp - 09-20-2021 (09-20-2021, 06:26 AM)E11even_Hunnit_imp Wrote: In 4 dyno numbers as well... TSR on the airbox? Or TSR velocity stacks on the TBs? Depending on the answer- you are probably on either side of 95whp RE: Double stack- hold the cheese - E11even_Hunnit - 09-21-2021 (09-20-2021, 11:43 AM)PowerDubs_imp Wrote:(09-20-2021, 06:26 AM)E11even_Hunnit_imp Wrote: In 4 dyno numbers as well... TSR on the airbox? Or TSR velocity stacks on the TBs? Depending on the answer- you are probably on either side of 95whp Stock rear "snorkel" delete w/ TSR funnel inlet housing a HF k&n. I really wanted to believe I was at the 100HP mark but you burst that bubble with your well documented(& dyno'd) setup. And I respect that RE: Double stack- hold the cheese - PowerDubs_imp - 09-21-2021 Do this to your stock stacks- and you will be very close to 100- http://cb1100forum.com/forum/showthread.php?tid=10300&pid=164988 Or wait until I test these new ones I am doing here- and you might get even better results- with plug and play- no grinding needed. I'm hoping (and expecting) a pretty decent gain over where I already am just by bolting these in...as in -wow, no brainer! gain... RE: Double stack- hold the cheese - E11even_Hunnit - 09-22-2021 (09-21-2021, 12:00 PM)PowerDubs_imp Wrote: Do this to your stock stacks- and you will be very close to 100- http://cb1100forum.com/forum/showthread.php?tid=10300&pid=164988 Yeah, I'm in no hurry to make more power atm. I will happily wait to see your results and root from the sidelines
Double stack- hold the cheese - PowerDubs_imp - 10-04-2021 ![]() ![]() Sent from my iPhone using Tapatalk I am very excited for these. They will derestrict our TB from the 26mm they are choked at- to allow the full 32mm - and then the new double stack improves airflow beyond the factory single design. Even on Honda bikes that use the same 32mm TB as our bike- with 32mm stacks from the factory. ![]() The CBR 650 uses the same 32mm TB as our bike- with full 32mm stacks from the factory- on an engine almost half the size. Going to a double stack design on a stock CBR 650, just swapped in without touching fueling- gained 3whp and no losses. I’m thinking we may approach closer to 110whp once I get these in. ![]() ![]() ![]() Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - tod.branko_imp - 10-04-2021 (10-04-2021, 12:01 AM)PowerDubs_imp Wrote:It's done? Put it on a Dyno and stick a price tag sir '14 CB1100 STD 5 speed |
