touching up cooling fins - Printable Version
+--- Thread: touching up cooling fins (/showthread.php?tid=4249)
RE: touching up cooling fins - GoldOxide_imp - 06-08-2023
(06-08-2023, 06:49 PM)The Gecko_imp Wrote: Mine is a EX, so Honda had even more time to fix it. After a million inline 4 built since the late 60s, one would think they know how to do it right. I was willing to attribute it to stone chips, but now I am .... disappointed ...
well ... at least a little. But won’t do much about it for now.
Honda mostly likely nailed the process down long ago. As with many things these days, that process would have to be "re-learned" when certain work is out sourced.
RE: touching up cooling fins - Charlie Bravo_imp - 06-09-2023
I'm getting a little bit of that, but it not noticeable from ten feet away so I'm not sweating it just yet.
RE: touching up cooling fins - Gone in 60 - 06-14-2023
Hey, 1973, thanks for the tip on that color!
I had been looking for a match, but couldn't find something that was really close.
RE: touching up cooling fins - 1973cb750 - 06-14-2023
(06-14-2023, 03:32 AM)Gone in 60_imp Wrote: Hey, 1973, thanks for the tip on that color!
i need to order another can its good stuff and a perfect match
RE: touching up cooling fins - max - 06-29-2023
Just got a can of the right sauce and it also works on the cb1000r exhaust, actually it works on the engine and wheels of the cb1000r too, literally sparkles a bit, good job 1973!
Since it is metallic it does need a good shake and thoughtful application ( runners etc. ) try it on something else first, the last time i applied high temp paint it was a bit soft until it gets a few heat cycles, then it hardens up nicely.
RE: touching up cooling fins - 1973cb750 - 06-29-2023
forks and wheels on the black cbs and the grab bars
