Here's one that might stump you - Printable Version
+--- Thread: Here's one that might stump you (/showthread.php?tid=4144)
RE: Here's one that might stump you - Tev62 - 08-30-2024
I wonder if the seals on the caliper are shot and the pistons are not fully returning to position? It's cheap enough for new oil & dust seals. The replacement operation will let you look at the pistons too to check for any corrosion that that might be causing an issue.
