Shim under bucket - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Shim under bucket (/showthread.php?tid=351) |
RE: Shim under bucket - dave - 11-07-2022 Honda regularly used hydraulic lifters on their early-to-mid 80's DOHC 16-valve inline-4s, and I think (?) their V4s also. Honda's V-4s do not use hydraulic lifters. RE: Shim under bucket - GoldOxide_imp - 11-07-2022 (11-07-2022, 07:34 AM)Dave_imp Wrote: Honda regularly used hydraulic lifters on their early-to-mid 80's DOHC 16-valve inline-4s, and I think (?) their V4s also. ... yeah, wasn't sure; and too lazy to check. Thx Dave. RE: Shim under bucket - Maturecheese_imp - 11-07-2022 (11-06-2022, 05:55 AM)The ferret_imp Wrote: Almost all of the manufacturers have adopted that system as the most dependable and trouble free Honda,Yamaha, Suzuki, Triumph etc I wasn't aware of that. Still it also makes servicing it it harder for the average home mechanic and therefore makes more money for the dealers, a common theme these days unfortunately. Some of us are not overly endowed with funds and sadly motorcycling has become a hobby of the better off, not as it was in my youth. I miss the simplicity of my bikes of the past like the Suzuki GS 550 and Yamaha XS 650. Without doing any real research (my bad) one of the reasons I went for an air cooled 4 was simplicity (I wanted an XJR 1300 but the fuel economy put me off) but it seems there are no motorcycles out there that are simple and basic anymore. I am, I must admit, out of practice after spending a couple of decades bikeless but even a simple job like removing the front sprocket involves removing a pump first and without a Haynes I'm reluctant to do it. Technology moves on i suppose and this forum is very useful at providing help and info so hats off to it. RE: Shim under bucket - the Ferret - 11-07-2022 Only a few do their own home mechanics, and most don't put enough miles on them to need to get into the internals before moving on to the next bike. It's not unusual to see 5-10 year old bikes for sale with less than 5,000 miles. Way before the first valve service is due. As a matter of fact they are just called valve "inspections" these days (to make sure they are still in spec) and that doesn't require cam removal. It's also not unusual on this forum and others I have been on for the home mechanic type, who do check their valve adjustments frequently to find them still in spec after 25-50,000 miles. My Honda ST 1300 never required a valve adjustment in 110,000 miles. I don't think the manufacturers went into it with the thought that if they went with the shim under bucket that they would make a lot of money from valve services. The XS 650's had a simpler adjustment but required adjusting more frequently as those valve arrangements were not as stable/reliable (I had (3) 650 Yamahas, a 73, a 79 and an 81). Having worked in the industry for 17 years from 1972-1989 I can tell you only a few did their own mechanics back then too. Most when needing service, other than an oil change or chain adjustment, brought their bikes into dealerships for service. Plus today working on stuff is a dying art. Millenials and Gen Z's have little desire to own vehicles much less work on them. Putting air in a tire is really a simple thing, but you'd be surprised at how many motorcyclists are not even any good at keeping up with that simple task at home. RE: Shim under bucket - peterbaron - 11-08-2022 ^^a very true statement^^ RE: Shim under bucket - Gone in 60 - 11-08-2022 Since most of you guys say that the valve clearances mostly stay in spec, I've figured that mine are still fine... right? I must admit that I have adopted the 12000 year interval that was for the later bikes, and, even as a meticulous mechanic, I don't feel the least bit guilty about it. Plus, the last time I did a valve adjustment, on my Triumph, it became a week-long affair that involved building a tool to retrieve a small bit that had fallen into the crank case.And that was just two cylinders. Some people can't even be bothered with looking at their tires, let alone checking the air. A few days ago, I was following a guy on a Harley who had a white stripe of cords easily visible on the back tire. I mentioned it to him, and he said "Huh, didn't notice.. thanks, I'll have it looked at." The one that gets me, not to get too far off-topic, is seeing a car with the license plate dangling from one screw. I think to myself "Is dealing with the nightmarish quagmire of the DMV to get a replacement for a lost plate really more appealing than finding one screw and sticking it in a hole?" RE: Shim under bucket - Nachodaddy - 11-08-2022 "There's a screw in my license plate? I better get that looked at." RE: Shim under bucket - Mixagon_imp - 11-08-2022 It says in my manual valve clearance check every 8000 miles or 12000km. I'm not worried about ignoring the first check and doubt I will ever reach the second check so that's me sorted ![]() My cb1100 is now just over 1000miles as its only used in good weather, I use my cb500x much more so that helps keep the 1100 milage low. The lack of owner's maintenance on some bikes surprises me, I often see really bad rusted chains nearly dragging on the road. One guy once asked me if I thought his clutch was slipping and on its way out. He showed me by trying to pull away with the front brake on and the bike not stalling. I couldn't believe what I saw.... the chain was slipping over the rear sprocket because the rear sprocket was toothless, and he was riding like that. Shim under bucket - PowerDubs_imp - 11-08-2022 I can only imagine the noise and vibration that it had to make on a rear sprocket before it ever got to the point of slipping. When I was young a friend of mine wanted to go out and ride dirt bikes with me so he bought an old 1970s Yamaha for a couple hundred dollars. About a month later and he was on the street doing burnouts by holding in the front brake, reving and dropping the clutch, a few times while tearing up and down the road and then went to do it again all you hear is rubbing it nothing was happening. Turns out the chain was now spinning over what was left of the front sprocket But in that situation it was a very beat up cheap bike, front sprocket out of view, and since it was a two stroke it was loud and rough anyway. Sent from my iPhone using Tapatalk RE: Shim under bucket - dave - 11-08-2022 Honda's V-4s do not use hydraulic lifters. [/quote] ... yeah, wasn't sure; and too lazy to check. Thx Dave. [/quote] You're welcome! My 1998 Honda VFR800 (best bike I ever owned) has gear driven cams. This makes it SO much easier to adjust the valves - no cam chain or cam chain sprocket(s) to remove. I performed the first two valve inspections on this bike at the recommended mileage, and both times all the clearances were in spec. I didn't have to adjust any valves until I reached 56,000 miles (bike now has 116,000 miles). |
