Engine Vibration - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Engine Vibration (/showthread.php?tid=2409) |
RE: Engine Vibration - 736cc_imp - 05-08-2016 (05-08-2016, 12:42 PM)Rboe_imp Wrote: Hmm, I wonder if you are feeling the engine lugging. Apparently I assumed it's not possible to lug w/ fuel injection above idle. But maybe the machine disagrees with my pushing its limits at those rpm's and throttle loadng. I read that the greatest possible mpg for a gas engine is achieved at the lowest rpm at full throttle. But the amount of load is a variable that changes the equation. "Hey Doctor, it hurts when I do this; what does that mean? Doctor replies "It means don't do that." So the answer to all this is the CB1100 shouldn't be rolled on at very low rpm's because it doesn't like that and signals that by a noticeable vibration. RE: Engine Vibration - uscgmac_imp - 05-08-2016 Try just the oposite and shift gears around 5000 to 5500 rpms or more and see how much fun you can have. This bike likes to be woken up also. It can be a real fun spirited ride in the upper rmps, and smooth too. I know its a fun relaxed bike to ride but nothing wrong riding it like a sport bike too sometimes:-) Ill meet up with you some day and compare notes. Im the one who saw your bike out in the Hamptons last week. Im also on the Island. You wouldnt of noticed me last week being i was one of those non waiving, loud pirate looking bad biker guys riding the oil leaking shake box. Lol. RE: Engine Vibration - beardyweirdy@me.com_imp - 05-08-2016 Sorry to get off topic, but.... 'What is that faring 736cc? And how does it feel? RE: Engine Vibration - CIP57_imp - 05-08-2016 I assume your talking about first gear roll-ons and not upper gears. Roll-ons from that low in the range should be gradual otherwise you will get bog and vibration unless you slip the clutch. Fuel injection (lower gear restrictions)is not set-up for full throttle response @ such a low RPM unless there removed. You can snap the throttle above 3500rpms with no lag or vibration. Just the design of modern EFI bikes. Edit: You mentioned fuel economy, if your talking about top gear roll-ons 1 tooth up is about 3700prm's @ 70mph in 5th gear. Most manufactures measure 60-80 roll-ons for large displacement which is about 3200-4600 rpms on this bike. 2100 RPMS would putt you around 40-45 MPH in top gear. You would have to feather the throttle not to get vibration in a inline four. RE: Engine Vibration - Ulvetanna_imp - 05-09-2016 (05-08-2016, 01:13 PM)736cc_imp Wrote:I read that the greatest possible mpg for a gas engine is achieved at the lowest rpm at full throttle. But the amount of load is a variable that changes the equation. That is true in theory but mostly applies to piston aircraft. Those engines run at a constant throttle setting and RPM for long periods of time and are made to do so. All kinds of detailed charts are provided to tell the pilot where to set the throttle(s), props, mixtures, per altitude and speed and so on.(05-08-2016, 12:42 PM)Rboe_imp Wrote: Hmm, I wonder if you are feeling the engine lugging. You could gear a bike super-tall and it would trudge along OK on perfectly flat ground but bikes are geared to have some surplus power to handle the rise and fall of the terrain, and allow for some degree of acceleration for safety's sake. You have more control at higher RPM, as I mentioned, when I get into traffic on the freeway I'll drop to fourth or third while maintaining the same speed to assure plenty of maneuvering power, until I get into the clear again. Your bike engines are designed to run that way, it's for the safety of the rider. You want great mileage, a Prius will do the job. RE: Engine Vibration - 736cc_imp - 05-09-2016 All great replies. Reason I brought up the subject is because I'm riding quite a bit more conservative and relaxed lately. Maybe I'll go back to being a squid.... RE: Engine Vibration - emptysea - 05-09-2016 There's a balance between "Grandpa" and "Squid", 736cc. We have found that installing RLETs helps one find this balance. Install them and discover the joy that is the CB1100. RE: Engine Vibration - the Ferret - 05-09-2016
RE: Engine Vibration - rboe - 05-09-2016 I'm typically not that aggressive with my roll ons, but now it sounds like I'm more aggressive than you are at the moment. Lugging is not good, so I'll recommend that you dial in a wee bit more gas. This motor will pull from idle with no throttle no problem; but down in Phoenix you don't want folks running up your back side (they can be an impatient lot) but it does not take much throttle to move out briskly - yet avoid the squid behavior. My Griso is my hooligan bike, and even that one rarely gets ridden hard (it too quickly gets me in over my head..... ), while the CB does offer some excitement in the upper rpm's, it is not as satisfying as letting the big steam engine of the Griso loose. It's a Guzzi thing.
RE: Engine Vibration - 736cc_imp - 05-09-2016 What's RLETs? |
