At what RPM do you cruise? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: At what RPM do you cruise? (/showthread.php?tid=1500) |
RE: At what RPM do you cruise? - Wisedrum - 04-22-2018 The streets and roads where I live lead through plain land. I mostly switch up into the 5th gear with my 2013 CB and stay there between 2.000 and 4.000 rpm. More often than less I do not leave this range. Seldom do I ride faster than 120km/h. Only on longer trips I speed the CB up to 5.000 and a little more rpm where it is allowed. The engine becomes thirstier. Over all the CB feels like an automatic motor been drivin' this way. I prefer the smooth pull in the last gear over the more speedy acceleration in the lower gears with higher revs. Sometimes I jump gears like going from 1st to 3nd right into 5th. The CB can do this stuff effortlessly. Wisedrum RE: At what RPM do you cruise? - alprider - 04-22-2018 my goal always . as low rpms as possible....or just in the highest gear as possible....just speed 30mile/50km absolut no problems (too some slower) or simple hill up in 6 RE: At what RPM do you cruise? - tuareg - 04-22-2018 I usually ride at around 3000 rpm@5th gear(2013 w/5-speed) which more or less corresponds to the legal speed limit. I go up thru the gears quickly and stay there. In urban areas I drop to 3rd, so with the familiar buzz at 2500 rpm I can ride at 50 km/h without looking at the clocks(and avoid getting "blitzed"). On the Autobahn i have ridden at 5000+ rpm for extended periods, with short streaks of top speed and surely that is nothing the CB can't handle. These engines are designed to handle much worse, and the occasional lugging even helps. RE: At what RPM do you cruise? - cookiemech - 04-22-2018 I'm gonna be the outlier that says "2000 to 2500 rpm" when I'm just riding around. The engine definitely is not lugging at 2k rpm; I can shift that thing up to sixth at about 40 mph and just pretend it's an automatic. Doubt I've ever run it much above 4000 rpm; it just doesn't ask me to do it. This would be in contrast to my other bikes: Harley Touring bikes - 2500 to 3000 rpm; old BMW K75s - 3500 to 4000 rpm, KLR 650 - 3500 to 4500 rpm. Low rpms on the CB just might be the reason I see over 50 mpg all the time! RE: At what RPM do you cruise? - jimgl3_imp - 04-22-2018 this is why I'm trying to find a 37 tooth steel rear sprocket RE: At what RPM do you cruise? - Roper_imp - 04-22-2018 Cruising: 2500 - 3500 rpm. More "spirited" riding: Above 5000, with the occasional redline before a shift
RE: At what RPM do you cruise? - Rocky_imp - 04-22-2018 On a freeway, sixth gear and whatever rpm that may be. 95% of my riding is not on freeways or high-speed roads so I don't pay attention to rpm. I ride the winding coastal and country backroads where the fun is. RE: At what RPM do you cruise? - rotor - 04-22-2018 (04-22-2018, 09:22 AM)jeffmazz_imp Wrote: Wondering at what RPM everyone likes to cruise their CB. I try to keep mine at or around the 3,000 RPM range. There's plenty of torque to cruise at much lower RPM but I don't want to lug the engine. What are your thoughts on the optimum cruise RPM? Just before any further reduction would make the engine labour. Once you know your engine well enough, you can hear it complain. On this bike it is rather low, in the vicinity of 3K - but it depends on the load: uphill and against the wind will require perceptibly higher revs. And we must never forget that on a motorcycle, the engine works mostly to push the object through the fluid, and the fluid resists with the force that is proportional to the velocity squared. Just listen to what the engine is telling you... At what RPM do you cruise? - mattmcuomo@yahoo.com - 04-23-2018 ![]() Sent from my iPhone using Tapatalk RE: At what RPM do you cruise? - misterprofessionality - 04-23-2018 LOL...MMC just encapsulated my life in one image. |
