Riding in the Rain: A Pragmatic Response - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Motorcycle - Riding Techniques (https://cb1100forum.net/forum/forumdisplay.php?fid=34) +--- Thread: Riding in the Rain: A Pragmatic Response (/showthread.php?tid=14746) Pages:
1
2
RE: Riding in the Rain: A Pragmatic Response - Cormanus - 04-22-2026 That looks like a good storm to sit in an underpass for. RE: Riding in the Rain: A Pragmatic Response - pdedse - 04-22-2026 I love the "guy flying off his motorcycle caution sign". And the RE INT650 is a wonderful bike with a very high fun factor. RE: Riding in the Rain: A Pragmatic Response - Nachodaddy - 04-22-2026 You always must consider how the other drivers will handle the slick roads, especially in a place, like Phoenix, AZ, USA, where they do not often drive on slick roads. There is nothing as exciting as having a huge vehicle slide across the road sideways right in your path. RE: Riding in the Rain: A Pragmatic Response - Gone in 60 - 04-22-2026 Nice ride on the Interceptor! I rented one too, which is how I got hooked and ended up buying one. You won't regret it. I miss mine though... she's been parked and covered in a friend's garage since I started the delivery job and have the BMWs cycling through my garage. Hopefully we'll get more business in my area soon, and I can rent a shop for the work bikes. In my area, the cars typically lose control in the rain on the wraparound freeway on ramps. Sometimes you'll see a tow truck parked in the center of an on ramp in the rain, just waiting for his next customer. RE: Riding in the Rain: A Pragmatic Response - FlyerRon - 05-22-2026 (04-18-2026, 11:07 PM)rdprdp01 Wrote: Recently, I rode my motorcycle downtown to pick up some fruits and vegetables. The skies were gray, and rain was in the forecast. But I rode anyway. It has been too long since I navigated a wet road. I needed the practice.David, tell me about the ceramic coating that you use on everything. Brand name, etc.? Thanks in advance ... Ron RE: Riding in the Rain: A Pragmatic Response - rdprdp01 - 05-22-2026 Great to hear from you. For my motorcycle, I used the Chemical Guys' Carbon Force. I liked it because it is a professional-grade, thick coating. I did the work myself because I struggled to find a detailer willing to go the extra mile on intricate services like wheels, spokes, cable ends, etc. Although cars are obviously much bigger, they may be easier to coat because the surfaces to be coated are flat rather than round, as on our motorcycles. See a credible review for details about Carbon Force and other options: Car and Driver Ceramic Coating Review Because I am not a detailer by trade and do not have customers screaming at me about when the motorcycle can be picked up, I took my time and deviated a little from standard applications. I actually applied four "thin" coats to build up to a thick, protective coating. The thin coating approach also helped me ensure that everything was as smooth and cool as the other side of the pillow. Here are the notes I took from my maintenance journal: Applying Carbon Force Ceramic Coating requires flawless preparation. The process involves washing, decontaminating, and polishing the paint. Work in a cool, shaded environment. Apply the coating to a small section in a cross-hatch pattern, allow it to flash for 60 seconds, and buff off the residue. Step 1: Prep the Vehicle Proper preparation is the most critical part of a ceramic coating, as it permanently locks in whatever is on your paint. 1. Wash: Give the vehicle a thorough wash using a wax-free, gloss-free soap (such as Clean Slate) to strip away old waxes or sealants. 2. Decontaminate: Use a clay bar and lubricant to safely lift embedded dirt, rail dust, and other impurities from the paint. 3. Polish (Paint Correction): Remove any swirl marks, scratches, or oxidation using a machine polisher and fine polish so the paint is perfectly clear. 4. Wipe Down: Remove all polishing oils and residue using a surface cleanser like Wipe Out. This ensures the coating bonds directly to the clear coat. Step 2: Apply the Coating 1. Prep the Applicator: Drape the micro-suede applicator over the foam block. Place the bottle against the applicator and tilt to dispense a couple of thin lines of Carbon Force onto the suede. 2. Apply in Sections: Work on a small area or a single panel at a time. 3. Cross-Hatch Pattern: Gently spread the coating onto the paint using linear (up-and-down and side-to-side) motions to create a cross-hatch pattern. Do not use circular motions. Ensure you have complete, even coverage without heavy pressure. 4. Let it Flash: Allow the coating to "flash" or set for about 60 seconds. You will see a faint rainbow-like or oily film appear on the surface. Step 3: Buff and Cure 1. Buff Off: Fold a clean, premium, short-pile microfiber towel (like the Workhorse Towel) into quarters. Gently wipe the surface side to side to remove any excess residue. 2. Inspect: Switch to a fresh microfiber towel to do a final wipe and catch any high spots (streaks or leftover material). 3. Cure Time: Let the vehicle cure for at least 12 hours in a controlled, dry, indoor environment away from moisture and dust. Avoid washing the car or exposing it to rain for at least a few days to let the coating fully harden. With all the surfaces treated (vinyl, chrome, paint, and metal), I can detail my motorcycle in no more than 20 minutes using the other products Chemical Guys sells. Usually, it takes less than 5 minutes. I do not use soap and water. Rather, I use a microfiber cloth and a spray cleaner designed for ceramic-coated surfaces. Although I have not seen it referenced in the literature, I suspect ceramic coating also extends the life of parts exposed to the elements. I had my cars professionally detailed by great detailers. I believe the Ceramic Pro Product Line is the gold standard and capable of the 10-year mark with reasonable maintenance. Their network of detailers is a qualified list. They go the extra mile to make sure the prep and application are right. When I last had a car coated, the 9H product was the premium coating. Ceramic Pro ION appears to have taken it to the next level. Once a year, I have the cars professionally detailed. At that time, I intend to ask them to apply one coat of Ceramic Pro ION to my existing finish. |
