When would you consider an engine 'run in'? - Printable Version
+--- Thread: When would you consider an engine 'run in'? (/showthread.php?tid=1397)
RE: When would you consider an engine 'run in'? - tuareg - 07-03-2018
With the motorcycle properly and regularly ridden, pretty much everything should have settled/seated/mated by the second oil change, whenever that is. Except, of course, the proverbial valve clearance issue needs to be addressed from time to time Wink
