wobble and weave - Printable Version
+--- Thread: wobble and weave (/showthread.php?tid=13538)
RE: wobble and weave - chync_imp - 04-10-2017
I would also check your triple tree bearings just to make sure you don't have something adding to the problem. You can pull on the front forks when the bike is on the center stand to see how much play you have. You can also adjust the tension on the triple tree bolt to adjust the resistance or lack thereof in the steering.
RE: wobble and weave - Lord Popgun - 04-10-2017
And here is how to adjust the steering stem: http://cb1100forum.com/forum/showthread.php?tid=5860&pid=124964#pid124964
RE: wobble and weave - jimgl3_imp - 04-10-2017
my rz350 used to shake it's head when leaned over in a turn. i wondered if it had been crashed and wasn't true somewhere.
