When it rains, it pours - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Motorcycling - General (https://cb1100forum.net/forum/forumdisplay.php?fid=19) +--- Thread: When it rains, it pours (/showthread.php?tid=13410) |
RE: When it rains, it pours - PowerDubs_imp - 05-12-2018 Glad you didn't eat it.
RE: When it rains, it pours - max - 05-12-2018 Nice save ferret, those original batteries are the best gel batteries i have seen on motorbikes, mine is 8 years old and when i measured the capacity by charging/discharging the battery it still had half ( 5 ah ) the capacity left, considering the vibration and bumps on the lead plates that is good going. For the rear brake;only three things are preventing the piston to move "home" after pressure is released; dirt and oxidation, a stiff square "o" ring ( which does not slide but deforms a bit and grabs the piston when pressure is applied ) and a blocked very tiny hole just in front of the rubber cup in the master cilinder, so small i could not see it in my old cb550 ( as it was blocked ) and had to see a photo to identify the place where it must be before carefully opening it up with a fine needle after which the air bubbles came out and i could bleed the system. Good to see you guys having better weather over there and an avalanche of new riders. RE: When it rains, it pours - Cormanus - 05-12-2018 Good save, Ferret. Glad you and Mrs Ferret are OK. What a nasty experience. RE: When it rains, it pours - pdedse - 05-12-2018 Wow! Glad to hear that nothing serious came of it. RE: When it rains, it pours - 2017EX_imp - 05-12-2018 Ditto! Glad you are both OK! RE: When it rains, it pours - Lord Popgun - 05-12-2018 Max, The ST has a secondary master cylinder on the left fork. It will activate a piston in the rear brake when the forks compress. Noted for being a problem in the ST’s. RE: When it rains, it pours - the Ferret - 05-12-2018 (05-12-2018, 07:34 AM)Lord Popgun_imp Wrote: Max, and Goldwings. There was a recall on the Goldwing SMC but no recall on the ST's. Honda's idea of safer braking in that no matter what you do, both front and rear brake get used, every time. When it rains, it pours - dsan1964_imp - 05-12-2018 (05-12-2018, 02:51 AM)The ferret_imp Wrote: Known, but fairly rare issue on the ST's. I had my fluids changed regularly and the smc cleaned, but apparently it's number was up at 109,900 miles. Well time for a new bike! What the heck.. glad y’all are fine! Sent from my iPhone using Tapatalk RE: When it rains, it pours - LongRanger_imp - 05-12-2018 Ferret, good save. Sorry the Mrs. had to experience that but I'm glad you have the skill and experience to handle it. The skid, that is. I have no idea if you have the skill and experience to handle the Mrs.! Serendipity about the timing. I brought the K1200RS to the dealer today to replace the brake and clutch fluid. It's been three years, and while I live in an arid climate, the ABS pumps / modulators on these bikes are $2000 to replace and tend to fail if the fluid is neglected. I'll be curious to know the cause of failure on your ST. RE: When it rains, it pours - max - 05-12-2018 (05-12-2018, 07:34 AM)Lord Popgun_imp Wrote: Max, Thanks popgun, we learn..... |
