Chain adjustments - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Chain adjustments (/showthread.php?tid=1337) Pages:
1
2
Chain adjustments - pittycheria_imp - 07-30-2018 (07-22-2018, 02:24 PM)The ferret_imp Wrote: this may help if you read the explanations, but the pics are long gone thanks to photobucket. Thank you Sent from my iPhone using Tapatalk RE: Chain adjustments - DBM_imp - 07-31-2018 WD 40 is a Water Dispersant mixed with solvent chemicals. It is very hard on the rubber oring seals on a chain. I use kerosene (engine flush) in a spray bottle, then wipe dry with cloth rags. Then l carefully blow off any remaining residue with my compressor. I would never use water to wash a chain. After cleaning, go for a short ride to warm up the chain and then lube on the center stand spinning the tire in reverse. RE: Chain adjustments - PowerDubs_imp - 07-31-2018 It may be lore- but I'd heard many many year ago that the 40 was because it was the 40th attempted blend of whatever- meaning they tried 39 other things first before settling on that. RE: Chain adjustments - apex1_imp - 08-31-2018 I found this tool on a YouTube video and ordered one today. It is called a Grease Ninja and supposedly makes lubing a chain easy and clean. Hopefully it works. http://www.greaseninja.com/ |
