The Case of the Too-powerful bike - Printable Version
+--- Thread: The Case of the Too-powerful bike (/showthread.php?tid=13222)
Pages: 1 2 3
RE: The Case of the Too-powerful bike - postoak_imp - 10-31-2019
You consider the CB1100 "lesser tiered"?
Of course you can wind the CB up, but you are going so fast, even in first gear, that it is mostly illegal to do so.
RE: The Case of the Too-powerful bike - GoldOxide_imp - 10-31-2019
(10-31-2019, 03:23 AM)postoak_imp Wrote: You consider the CB1100 "lesser tiered"?
Of course, and in the context of performance, the CB1100 is definitely lesser tiered compared to super sport models.
However, it was higher-tiered in the context of a more sedate peers (e.g. a thumper, a scooter, many upright street bikes in the the 650 to 850 engine size class). This was my frame of reference.
The Case of the Too-powerful bike - chync_imp - 10-31-2019
I have a slightly different perspective on the subject but it’s in the same vein.
I bought my cb1100 originally because I thought the retro look and build style would make a good platform for creating a custom modern retro build. And it did. Very easy to modify and work on.
In the process I ended up making quite a few performance upgrades. Performance was never my initial goal but each upgrade made such a noticeable difference I kept going. And it was just fun.
I ended up reducing the weight of the bike, adding hp with intake, exhaust, and fuel mapping mods, increasing acceleration with gearing and 17” wheels, upgrading to race level suspension. All that also required improving braking with ss lines and aggressive pads. The bike will flat out fly off the line and it’s able to handle aggressive turns safely.
I live in North Carolina and spend all of my time riding in the mountains on some of the the best and most challenging roads for sport bikes. As I learned how to push the bike further I realized just how much work it was taming all of that weight. Handling the power on it takes some finesse. Not nearly as much finesse as a modern super sport liter bike but I learned it was quite capable of losing rear grip if using too much throttle in a turn and it will power wheelie in first gear under hard acceleration.
But I find managing all that weight while trying to ride it like a sport bike is what seems like wasted effort. All that torque and power combined with the performance mods let me do things on it that it certainly wasn’t designed for and that I probably shouldn’t do anyway.
This year I set out to find a sport bike to satisfy my need for fun mountain riding that is appropriately suited for street and some highway riding.
My requirements were:
- sport or sport naked oriented design
- a more relaxed riding position than a super sport
- comfortable enough to do some touring
- enough power to be fun without requiring moto gp skills to handle
- enough acceleration at highway speeds to be safe from people driving mobile phone booths
- suspension that can handle twisty mountain roads
- something that won’t kill you for using most of the throttle
- least amount of weight that meets the other requirements
- preference for new over used
- under $10k
I looked at the 600cc and 800cc range of new bikes and I think from a power perspective I would have preferred an 800cc machine but the models I liked were sport tourers that weren’t light.
I ended up buying a 2019 Honda CBR650R and so far it’s been perfect. It seems to have a very usable power range that extends only just beyond reasonable fun. It doesn’t need electronic power control to keep you safe. Stock it weighs 450lbs and I have already been able to reduce that further. For comparison the 2017 CBR1000RR fireblade weighs 430lbs wet at nearly 200 hp. That’s insane when compared to the cb1100.
Riding the 650 on the same roads and at the same speed as the 1100 feels like gliding rather than keeping a barge in check. I have ridden an 8 hour day with no pain in my wrists or knees. And I feel confident and safe on the highway with its ability to accelerate out of harms way.
I definitely agree that there are bikes meant for the track out on the street for which there really is no safe way to use all available capabilities. Personally I wouldn’t put the cb1100 in that category but it certainly is possible to get it to do things it wasn’t intended to do with that big engine.
I’m loving the 1100 for what it does best and the 650 for spirited riding in the twisties. I’m a firm believer in the right tool for the job.
I can’t say the 650 is more fun than the 1100 across the board but it’s definitely more fun in super curvy roads.
RE: The Case of the Too-powerful bike - Stichill_imp - 10-31-2019
There are several things that can happen when HP goes up:
[ul] [li]Bike gets heavier[/li] [li]Bike gets longer[/li] [li]Bike gets taller[/li] [li]Fuel tank gets bigger[/li] [li]Tires get wider[/li] [li]Brakes get larger / lever effort increases[/li] [li]Clutch gets heavier / lever effort increases[/li] [li]Engine heat increases
[/li][/ul] What this all means when put together is that a big part of the fun of a motorcycle — nimbleness — is lost in the effort to generate and manage higher HP.
I seem to always have more fun riding my CBR250R than I do any other bike. Yes, I've had bikes that are more comfortable or have much better passing power, but nothing to me so far beats a small-bore bike for riding engagement. What ferret calls "work" — twisting the throttle repeatedly and shifting up/down in response to conditions to manage speed and momentum — is what I call rider involvement in the craft of motorcycling.
RE: The Case of the Too-powerful bike - chync_imp - 10-31-2019
I come across guys quite often riding modified Grom's on the same roads I do and I never meet one that doesn't look absolutely thrilled. Same goes for the guys on supermoto bikes.
RE: The Case of the Too-powerful bike - Houtman_imp - 10-31-2019
(10-31-2019, 10:11 AM)chync_imp Wrote: I come across guys quite often riding modified Grom's on the same roads I do and I never meet one that doesn't look absolutely thrilled. Same goes for the guys on supermoto bikes.
Your CBR 650 R is a great looking bike !
(10-31-2019, 10:05 AM)Stichill_imp Wrote: There are several things that can happen when HP goes up:
Your last sentence resonates with me, especially the last phrase.
(10-31-2019, 09:31 AM)chync_imp Wrote: I have a slightly different perspective on the subject but it’s in the same vein.
- under $10k
Great write-up chync.
- under $10k
lol - indeed.
RE: The Case of the Too-powerful bike - the Ferret - 10-31-2019
I can appreciate that. I really can. I've been there. Probably from 1965 up until the late 80s I was there. Can't imagine how many times I've twisted the throttle repeatedly, shifting up/down in response to conditions to manage speed and momentum. Hitting apexes, strafing turns, trail braking, side slipping, drafting, banging the swinging needle off the red line on the tach, braking hard, locking them up, sliding, counter steering. I'm certainly no stranger to the joy that kind of riding can provide to the so inclined.... BTDT a million times. Not to mention 10 years of racing Moto-X. I just ride a little differently now that I have a little age on me. I no longer need that extreme adrenelin rush to enjoy motorcycling. After 54 years of almost daily riding, I'm as happy now at 4000 rpms as I used to be at 9000 rpms. Don' t need the scares and close calls, being thankful for having survived that last fast run. It's why I appreciate bikes like the CB 1100 so much. It's a fun bike to ride easy. Shift if I want...don't shift if I don't feel like it. I don't have to work at riding, I just ride. Riding easier and enjoying it as much as ever.
RE: The Case of the Too-powerful bike - cooldrum_imp - 10-31-2019
There's something about riding small bore bikes. In addition to my CB, I also ride a '67 Honda 305 Scrambler. Yep, it has open pipes (no snuff or nots) and is a hoot to ride. Redline is 9000 rpm and that little twin moves along as you stir that 4 speed tranny. You're able to use all that power and you really become engaged while riding. Plus, it's so light that you can move it around easily on the road. Funny how we thought full litre bikes were the ticket to pure enjoyment when the small bore bikes can deliver just as much fun depending on how and where you ride. It's about the ride now and not necessarily the destination on why I ride these days.
