Austin to Terlingua - Printable Version
+--- Thread: Austin to Terlingua (/showthread.php?tid=11154)
RE: Austin to Terlingua - ishouldbuyatacotruck_imp - 09-29-2019
(09-27-2019, 11:46 AM)The ferret_imp Wrote: Tourmaster and Cortech make some great magnetic tank bags and strap on tail bags, or you might consider a dry bag ($12 or $14 for the last one I bought) from Wally World and some rok straps to put across the back of your seat
I wouldn't think you'd need extra fuel but I'm not familiar with the area. make extra gas stops if you have to ie: don't pass up a gas station if you are the least bit worried about running out.
Our tires are not readily available. If you are not familiar with the procedure for fixing a flat on the road or have a plug kit and compressor. At least join the AMA or AAA to get some tow coverage to the nearest dealership.
Thanks Ferret! I think I like [url=https://smile.amazon.com/Motorcycle-Resistant-Strong-Magnetic-Kawasaki/dp/B06XRS7L9H/ref=sr_1_9?keywords=tank+bag&qid=1569796047&s=gateway&sr=8-9]this bag for my tank - something simple that can keep my phone/map in front of me.
I don't think I'm super worried about gas - there are plenty of stations around. But just in case, I might order something small to keep with me when I go into the park. Something like [url=https://smile.amazon.com/REDA-Innovations-Fuel-Can-RGC1001/dp/B003WHBVDI/ref=sr_1_2?crid=2F5X5LXLOHX1S&keywords=motorcycle+gas+can&qid=1569796210&s=gateway&sprefix=motorcycle+gas%2Caps%2C168&sr=8-2]this one should work.
I'm not familiar with the flat-fixing process, but I'm sure I can study up between now and then. Curious, does [url=https://smile.amazon.com/Slime-10011-Emergency-Sealant-Trailer/dp/B000C11PYW/ref=sxin_5_osp64-2c6f53aa_cov?ascsubtag=2c6f53aa-87df-48af-be48-378552801008&creativeASIN=B000C11PYW&crid=2QE6UZPO1M87J&cv_ct_id=amzn1.osp.2c6f53aa-87df-48af-be48-378552801008&cv_ct_pg=search&cv_ct_wn=osp-search&keywords=motorcycle+tire+plug+kit&linkCode=oas&pd_rd_i=B000C11PYW&pd_rd_r=d012639a-e0ed-4107-9936-9c476905aed5&pd_rd_w=YA6Dr&pd_rd_wg=LE6Yt&pf_rd_p=53eff971-6e12-4016-9864-b6dfd929b2b3&pf_rd_r=CFDD1FFQC0DS7E12TZFN&qid=1569796273&s=gateway&sprefix=motorcycle+tire+plug%2Caps%2C165&tag=fsmag_os-20]this slime stuff work, in your opinion?
RE: Austin to Terlingua - Stichill - 09-29-2019
There is a gas station inside Big Bend National Park.
(09-28-2019, 12:29 PM)Stichill_imp Wrote: Three buddies and I did a very similar ride out of Austin in March of 2018. I posted a ride report [url=http://cb1100forum.com/forum/showthread.php?tid=12371]here if you'd like to review.
Would highly recommend the Marathon Motel in Marathon, TX and dinner at the 12 Gage Restaurant if you're in the mood for some fine cuisine.
[Image: 4db677b6423abb34489be096b6ac2844.jpg]
If the weather is nice you can take a dip in the Rio Grande here.
[Image: 0933235d0ccbb7e692c20bc32cf6a4f0.jpg]
Would definitely ride 170 west of Terlingua to Presidio through Big Bend State Park. Best time to see it is in the morning with the sun at your back.
Thanks Stichill! I've been going out to the Terlingua area since I was a kid. I love the hot springs! And 170 between Presidio and the ghost town is one of my favorites. I've visited DOM a few times. It's almost a rite of passage for boyfriends past to accompany me to my beautiful desert.
Thanks for posting the link to your journey - I'm so glad to see you enjoyed your trip around that part of Texas! I'm totally adding Chinto's to my list of places to stop. I promise to do a similar write-up of my journey.
Looking forward to pictures and stories! Biker
RE: Austin to Terlingua - the Ferret - 09-29-2019
Im not sure about the slime, have never used it. I dont think mechanics care for changing slimed tires though. Maybe some other forum members have tried it and could advise you on that.
Those small tank bags come in real handy, just dont leave your phone in the clear plastic map case in the direct sun for too long. My nephew did that and his phone overheated and stopped working until it cooled down.
RE: Austin to Terlingua - silverbub_imp - 09-30-2019
Regarding your strategy for repairing(temporarily) a roadside flat on your trip...consider that Wally's World has a tubeless tire kit(the one with the T-handles is my recommendation) that contains a "reamer" to prepare the nail type hole after extracting the nail(probably need a plier for that)...and then another T-handle tool that has an eye on the shank of tool to insert the "gummy-worm" to which has been liberally slathered with the "tire-gummy-glue"...for further details read kit instructions...to get the tire reasonably inflated...order online a CO2 cartridge kit that has an air chuck & multiple CO2 cartridges to air up the flat tire with the "gummy-plug" inserted into the nail hole...read carefully & follow instructions about using the CO2 cartridges as they will freeze your skin should you not wear gloves or other protection on cartridges while they discharge into tire...this procedure does not require you to unscrew the valve-core from tire as would be required using the liquid Slime...if your are still thinking about Slime...perhaps you should also check out a product called Ride-On...from my reading...and I have used Ride-On...but did not have a flat to check its effectiveness...however,...I have had roadside flats repaired using the GUMMY-WORM PROCEDURE/AIR-CHUCK/CO2 CARTRIDGES PROCEDURE to good results...even when having to use two "worms" in a large nail hole in center tread area...JUST A THOUGHT FOR YOU TO CONSIDER!...looks like a fine trip planned!!
RE: Austin to Terlingua - redbirds_imp - 10-01-2019
(09-30-2019, 06:05 AM)silverbub_imp Wrote: Regarding your strategy for repairing(temporarily) a roadside flat on your trip...consider that Wally's World has a tubeless tire kit(the one with the T-handles is my recommendation) that contains a "reamer" to prepare the nail type hole after extracting the nail(probably need a plier for that)...and then another T-handle tool that has an eye on the shank of tool to insert the "gummy-worm" to which has been liberally slathered with the "tire-gummy-glue"...for further details read kit instructions...to get the tire reasonably inflated...order online a CO2 cartridge kit that has an air chuck & multiple CO2 cartridges to air up the flat tire with the "gummy-plug" inserted into the nail hole...read carefully & follow instructions about using the CO2 cartridges as they will freeze your skin should you not wear gloves or other protection on cartridges while they discharge into tire...this procedure does not require you to unscrew the valve-core from tire as would be required using the liquid Slime...if your are still thinking about Slime...perhaps you should also check out a product called Ride-On...from my reading...and I have used Ride-On...but did not have a flat to check its effectiveness...however,...I have had roadside flats repaired using the GUMMY-WORM PROCEDURE/AIR-CHUCK/CO2 CARTRIDGES PROCEDURE to good results...even when having to use two "worms" in a large nail hole in center tread area...JUST A THOUGHT FOR YOU TO CONSIDER!...looks like a fine trip planned!!
I agree, good kit. Repaired a tire on my truck using this and it held for the life of the tire.
RE: Austin to Terlingua - Charlie Bravo_imp - 10-02-2019
Looks like a fun ride. Back in the day, 1971 to be sure, I rode a '70 Triumph Bonnie from Ft. Hood down to Corpus Christie and back. When they say it's floodin' down in Texas, they tellin' the truth! Water on the road flowing from one field to another was hub-deep. I am moving to TX from SoCal next year to be closer to my son and his family, near Ft. Worth. Looking forward to riding there.
