Beadrider Anyone - Printable Version
+--- Thread: Beadrider Anyone (/showthread.php?tid=10888)
Pages: 1 2 3
RE: Beadrider Anyone - oldgoat01_imp - 06-01-2013
Two questions regarding he AirHawk. First, how cool is it? GA summers are the same so you understand hot and humid. Second, how easy is it to move around and change positions? I always felt like you would kinda sink down on it and be cradled into a fixed position
RE: Beadrider Anyone - Bonafide_imp - 06-01-2013
(06-01-2013, 10:40 PM)oldgoat01_imp Wrote: Two questions regarding he AirHawk. First, how cool is it? GA summers are the same so you understand hot and humid. Second, how easy is it to move around and change positions? I always felt like you would kinda sink down on it and be cradled into a fixed position
Well .. I cant compare it to a beadrider cause I've never used one - so not sure about the air flow/etc but you're cods are not mashed flat on the seat - so it must keep them cooler than usual.
I hope this makes sense. The cushion itself is gridded like an egg crate - but the air inside can disperse between each grid depending on pressure from other grids. This keeps you from developing a pressure/hot spot on a contact point. When your weight shifts - the air inside the cushion shifts and compensates. There's an air valve so you can adjust how firm or soft you want the cushion.
Here's a pic of what I'm trying to describe ..
[Image: f5060757fe999b93abd0e4d895ba1c44.jpg]
RE: Beadrider Anyone - oldgoat01_imp - 06-02-2013
Thanks. Hmm. I've thought about an after-market seat and if I did I would add some height anyhow. So while a lot more $ than the beadrider, it's a lot less than a new seat + beadrider. I, too, would be interested in the measurements.
RE: Beadrider Anyone - Bonafide_imp - 06-02-2013
It's the 14x14. I dont like promoting eBay links without asking the forum owner, but here's the item number: 290699290243 - I have no ties to the seller.
(06-02-2013, 05:21 AM)Bonafide_imp Wrote: It's the 14x14. I dont like promoting eBay links without asking the forum owner, but here's the item number: 290699290243 - I have no ties to the seller.
Oh yeah, sure. Now I know your game. While sitting at home last night in my favorite chair with my tin foil hat on, you telepathically sent the mental image of my old beadrider to my brain, knowing I would immediately post a thread about the beadrider. This, in turn allowed you to cleverly do the old bait and switch: "beadrider, never heard of it, but I do have an Airhawk" As a result two of us have already inquired about it. And now, you just happen to have a link to the Airhawk. I see it all so clearly now. Not so fast however, as I have adjusted the antenna on my tin foil hat to pint to the South. So there! Big Grin
thanks for the link, I may just go that direction
RE: Beadrider Anyone - Randy B - 06-02-2013
Ever heard of "MGPS" mapping? Wink We don't use no terrestrial based broadcasting here buddy!!
Uh ... Whu?
MGPS....i.e. mind reading and mind location.
Dems just jokes. Big Grin
RE: Beadrider Anyone - CA200_imp - 06-05-2013
I tried the Air Hawk II and a gel pad and I used to sell bead seats but for me they just didn't work out unless you had to do
a lot of interstate. They just all move around funny.
RE: Beadrider Anyone - oldgoat01_imp - 06-05-2013
I found the beadrider to be pretty a good option for hot, humid weather; however, I've decided to try out the Airhawk, since the Airhawk 2 isn't that much more $. When I had last looked at Airhawk, they didn't have the cheaper model, meaning the Airhawk was 3x more than the beadrider. I figure $70 is a lot less than a new seat And I have my Alaske buttpad when it gets colder so I should be all set.
