Really tire time! - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Really tire time! (/showthread.php?tid=1043) Pages:
1
2
RE: Really tire time! - Rocky_imp - 07-01-2019 (07-01-2019, 01:25 PM)Rboe_imp Wrote: The rear can be fiddly until you've done it a couple times. I used to have a specially spaced (thick) board to support the tire at the correct height for the install. Last time I just got "close" enough. Good tip about the board. I do the same thing to support the weight of the wheel and line it up RE: Really tire time! - Ben70_imp - 07-01-2019 Along with the board, a dowel inserted from the brake rotor side helps keep the parts aligned while inserting the axle. I just use my original axle. The one I ruined the threads on the first time I replaced the rear tire... ![]() Ben RE: Really tire time! - Rocky_imp - 07-01-2019 (07-01-2019, 11:26 PM)Ben70_imp Wrote: Along with the board, a dowel inserted from the brake rotor side helps keep the parts aligned while inserting the axle. I just use my original axle. The one I ruined the threads on the first time I replaced the rear tire... Another good tip. Thanks Oops, we'll pretend we didn't see that about the axle
RE: Really tire time! - ohiorider_imp - 07-02-2019 Questions: 1. I removed the rear axle spacers before taking my wheel to the shop for a new tire. I'll remember which goes in the right side, which goes in the left. Sure I will! 2. Has anyone gotten them crossed up while changing a tire, and if so, would it even be possible to remount the wheel? I took a close look at the right and left spacers (the part that is visible once wheel is mounted and torqued to spec. The spacer on the brake rotor (right) side appears to clear the wheel hub by approximately 1/16" The spacer on the sprocket (left) side clears the hub by approximately 3/16". I no longer maintain a Photobucket account, but if one of you knowledgeable forum members could send me your email address, I could take a couple of pics and send them as an email attachment. Thanks, Bob RE: Really tire time! - Rocky_imp - 07-02-2019 I haven't removed the rear wheel on the CB yet so can't offer any help. FWIW, when I remove a wheel I remove only one spacer at a time (if there are two), clean it up and use a Sharpie to write an R (right) or L (left) on it. I also mark an arrow on it to indicate the edge that goes in first - even if either way is OK. The way it came out is the way it goes back in - regardless. RE: Really tire time! - Lord Popgun - 07-02-2019 Ohiorider, I just looked at my bike and the right spacer is not showing much and the left is. I didn’t measure, but looks to be about what you posted. And is what the service manual shows. If they were swapped I don’t think the wheel would mount as the disk would be out of place. Its been about 3 years since I had my wheels off, but I don’t remember the spacers being a problem as the book shows the proper side for each. Do you have a service manual? If not, PM me and I can send the page to you. RE: Really tire time! - ohiorider_imp - 07-02-2019 (07-02-2019, 10:10 AM)Lord Popgun_imp Wrote: Ohiorider, I just looked at my bike and the right spacer is not showing much and the left is. I didn’t measure, but looks to be about what you posted. And is what the service manual shows.PM Sent. Bob |
