Chain lube - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Motorcycling - General (https://cb1100forum.net/forum/forumdisplay.php?fid=19) +--- Thread: Chain lube (/showthread.php?tid=13044) |
RE: Chain lube - rboe - 06-18-2021 I remembered to turn it off while hauling in the back of the truck. I did forget to turn it on the first day riding...... Oops.
RE: Chain lube - Stichill - 06-18-2021 (06-18-2021, 05:03 AM)Rboe_imp Wrote: I remembered to turn it off while hauling in the back of the truck. I did forget to turn it on the first day riding...... Oops. I put a label on my GPS: "CHECK TUTORO"
RE: Chain lube - Scotty_imp - 07-19-2021 (06-14-2021, 09:02 AM)Stichill_imp Wrote: The Tutoro chain oiler acquitted itself nicely during my Utah ride on dusty, sandy gravel and dirt roads. I've never used one. Interested. What kind of oil do you use in the reservoir? RE: Chain lube - GoldOxide_imp - 07-19-2021 Tutoro offers a selection of two oils: Normal and Hot Weather recipes. I currently use 5W40 full synthetic general motor oil, and never conventional. RE: Chain lube - j3gq_imp - 08-19-2021 [quote='Rboe' pid='296084' dateline='1620755332'] I am looking at your 2nd pic here: on a very hot day, may be while you stop for a coffee in Phoenix in July, the end of this little blue tube may give more to gravity then you imagined. Back on the road, caught between chain and sprocket, it may take you for a “ride” of the unexpected kind. RE: Chain lube - rboe - 08-19-2021 So far (knock on wood) the only problem - the hose came off the reservoir once. Might have to clamp it. Other bits are holding well. But since you brought it up I'll keep an eye on it just in case. |
