Double stack- hold the cheese - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Double stack- hold the cheese (/showthread.php?tid=4284) |
RE: Double stack- hold the cheese - 1973cb750 - 10-24-2022 thanks Double stack- hold the cheese - PowerDubs_imp - 11-16-2022 Shop that made these wants to try another set… different in design. No further info… and any progress will probably be several months since he is on the other side of the world. Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - JLEECB - 12-10-2022 I’ll be in Thailand next month if you need me to break some knee caps. (11-16-2022, 12:55 PM)PowerDubs_imp Wrote: Shop that made these wants to try another set… different in design. Double stack- hold the cheese - PowerDubs_imp - 12-15-2022 3 more different styles to test. ![]() Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - E11even_Hunnit - 03-07-2023 Can't believe it's been over a year, and you going thru all the back and forth with the shop has yet to yield ANY improvements. Crazy Tuned in and interested in seeing results on the revised versions vs. your last numbers. I want a >100HP CB11!! RE: Double stack- hold the cheese - PowerDubs_imp - 03-07-2023 Life gets in the way. Sooo much else going on. 100hp is easy. My last test was 104 RWHP.... which even at a conservative 10% drivetrain loss is 115 crank horsepower... and that's with putting down over 75 wheel torque! The bike... isn't slow. And with the new 4-4, sounds fantastic. Waiting on warm weather to get back to it... as I am now running split tuning- I am fueling the left 2 cylinders separately from the right 2. RE: Double stack- hold the cheese - 1973cb750 - 03-08-2023 power dubs im working on getting set up to flash tun the stock ecm hopefully i can figure it out id love to erase the speed limiter and change the timing vs gear tables wish me luck RE: Double stack- hold the cheese - Cormanus - 03-08-2023 I’ll wish you luck 1973cb750. Keep us posted. Double stack- hold the cheese - PowerDubs_imp - 03-08-2023 Yea- awesome to see others playing with this bike. If you decide to make a post about what ever it is that you are doing- I will definitely follow it. Sent from my iPhone using Tapatalk RE: Double stack- hold the cheese - 1973cb750 - 03-08-2023 Waiting on a tuning cable to try I have the software I believe and just a few other bits to figure out |
